Reviving another old relic - D9G
6 years 3 months ago #189182 by Billy-
Yeah, Doing the ram seals on the excavator as well at the moment, so we can lift it out with that. Then my mate is off on holiday for 2 months so it'll be a good time to get the bank account a bit healthier before we get back into it.
Looking forwards to seeing her up and running. Alot of these big old girls parked up now, never to run again so good to see one getting repaired and put to use.
6 years 1 week ago #192941 by Misterskill
Well, back into it. Main ram seals done on the excavator so back into the old rig
Track split and cylinder out. Clean it up tomorrow, then send the seals off to get replacements.
Also found a picture of it working back in the old days. 1967, she would have been a flash rig back then!
6 years 1 week ago #192957 by Misterskill
Yeah, seal is a little worn...
6 years 1 week ago #192975 by Paso Bob
Your old B & W photo is really cool. In it's day it would put out a lot of work, in fact it still will hopefully.
6 years 1 week ago #193024 by Misterskill
Yeah, we will get there!
Noticed an oil leak from the seal between the tank and the input shaft that comes off the front of the motor. Seal is shot and the shaft & coupling are showing signs of wear.
Rang cat as i figured i may as well change the shafts & coupling out to be told that whole pump is discontinued. The unit is still working however I'd like to be able to service it down the track if required.
Anyone come across this before? is there another later model pump that fits in or is it possible to retro-fit the later D9H style with the hydraulic tank up the top? or am i simply looking for the wrong item?
Pump assembly should be 3J-6737
hydraulic S/N is 91F1292 with control 193
Cheers
6 years 1 week ago #193030 by Deas Plant.
Replied by Deas Plant. on topic Hydraulics?
Hi, Misterskill.
The D9H system would be easier to retrofit than the D9G system 'cos the D9H system tank fits ahead of the fuel tank instead of being alongside the fuel tank which requires the fuel tank to be offset to the left. The hydraulic pumps are remote from the tank in both systems and there would be extensive re-plumbing required but it would be do-able if you had to.
6 years 1 week ago #193074 by Misterskill
Hi, Misterskill.
Had a look at a few examples of both today and you're right about the tank position. Pump is in the same spot on both which is currently just blanked off on mine so that should just be the matter of getting the adaptor plate and it should bolt straight in.
Split the hydraulic tank on mine and it contains a vickers 55v pump. Couldn't find much online but there was a place in the states who claim to work on them so fired them off an email inquiring about parts availability.
6 years 1 week ago #193079 by Deas Plant.
Replied by Deas Plant. on topic Vickers pump?
Hi, Misterskill.
Just be careful if you plan on using that Vickers pump in an external position that it wasn't designed to be fully surrounded by the hydraulic oil within the tank and will function O.K. out in the open.
5 years 11 months ago #193705 by Misterskill
Crisis averted. Found a place in usa that can provide one, with a seal kit and bearing.
Got the idlers apart, got the rubber bushes out after a bit of heat and some banging a crashing. Bit worn, so welded that up. New parts ordered. Bushes, top plates and wear plates
Welded a few cracks up, new trunnion ball coming so I'll cut that out this week. New ripper boots and shins
Coming along slowly.
5 years 11 months ago #193710 by Deas Plant.
Replied by Deas Plant. on topic Progress.
Hi, Misterskill.
Progress. GOOD stuff. It's always nice when doing projects like yours and you have win, like with the pump.
Time to create page: 0.423 seconds
