Reviving another old relic - D9G
6 years 5 months ago #185564 by d9gdon
Another tip is to use your tilt cylinder and it will slowly turn the tractor when pushing a blade full. That slows the wear on the steering clutches.
6 years 5 months ago #185567 by Misterskill
Thanks fellas,
Not breaking things or excessive wear is pretty high on the priority list when you are fixing these things yourself, so i'll take all that on board. plus its always easier to start off correctly then try and fix bad habits later
So looks like second gear at half throttle or just under and cruise in forward only. I'll stop halfway for a while, just because i can, and obviously watch the temp gauges. But she seems to run pretty well.
6 years 5 months ago #185568 by old-iron-habit
(quote) So looks like second gear at half throttle or just under and cruise in forward only. I'll stop halfway for a while, just because i can, and obviously watch the temp gauges. But she seems to run pretty well.(end quote)
Walking it home at half throttle should be OK but when you work it, keep in mind that these engines were designed to be run at "high idle" which is Cat speak for wide open throttle.
6 years 5 months ago #185753 by Billy-
Neat old tractor, would of been massive in its time and still is a big dozer. Beauty of the climate up there is corrosion should be minimal, not like a lot of dozers from wetter areas that suffer badly from corrosion when left outside to rot. Still quite a few 8's and 9's left sitting around in opal fields from what I hear. Most probably parked for a reason however this one appears a near tractor and fired up no worries! Good luck with it and keep us posted, a great era of dozer.
Cheers
Billy
6 years 5 months ago #185764 by Misterskill
Cheers
Billy
This one had a ticking noise in reverse apparently, so far so good though... the price i got it for i was expecting at least one major repair.
Big enough for me i reckon, found an old Komatsu D455A the other day. Everything is big and heavy on mine, let alone something like that...
Getting pretty thin on the ground these days. I think they all went to Mintabie when that took off and most didn't make it back.
So we loosened the track bleed valve and a little bit of grease came out, not much pressure. so we removed the valve, pumped a bit it in to watch it was going in, then put them back in and started filling it up.
We ended up assisting it a bit with a jack between the frame and the idler brackets. got about 50mm on one side (2inches) before it stopped moving as freely. then onto the other side, heap of grease and nothing. then it starts leaking oil? thinking it might the "track adjuster seal" i keep hearing so much about and hoping it's nothing more serious. it has been leaking for a while by the look of it. We were looking at trying and jack it apart and then fill with grease and see how it holds up.
Thanks for your help fellas, it's much appreciated. Get this old girl fixed up and back into it in no time!
6 years 5 months ago #185765 by Billy-
From what I hear parts are getting very thin on the ground for D355 and D455A's, would be quite a task taking ownership of one of them.
Sounds like you could be on a winner with that D9G, looks straight and got most track guards in place which is a bonus. Would of been warm mining for opal with that in the desert with no canopy!
Have heard there is a few cats lying around Mintabie, gonna be up there in Sept so good chance to have a scout around.
6 years 5 months ago #186045 by Misterskill
after about 4 tubes of grease and assisting it with a portapower the tracks finally came out! had a bit of a scratch around and the have gone back in a little bit, but still out a fair way compared to where they were.
trans oil change next weekend
6 years 3 months ago #189124 by Misterskill
Alright so we have had a bit of progress.
Drove the old girl home. Track seals are shot and She has trans issues in reverse so we blocked the tracks and i kept it in first and just cruised.
Hacked the blade to bits as per my other post
Did battle with these bolts. Broke a few tools before i ended up with a sledgehammer and slogging spanner.... Got one bolt out, the rest i cut.
Fun and games!
6 years 3 months ago #189172 by Billy-
Looks like your making good progress. Are you going to pull the tranny out for the reverse issue?
6 years 3 months ago #189181 by Misterskill
Yeah, Doing the ram seals on the excavator as well at the moment, so we can lift it out with that. Then my mate is off on holiday for 2 months so it'll be a good time to get the bank account a bit healthier before we get back into it.
Time to create page: 0.444 seconds
