D2 steering clutch
D2 steering clutch
Thank you received: 680
7 years 3 months ago #173012
I hope you have a better time on the inner hub than I did. I couldn't move mine so resorted to cutting it off. Even with a slice right through on one side, I had to crank on the puller til it popped. Hardest one I've ever removed
7 years 3 months ago #173013
by Chuck C
Neil I had to use heat on the outer drum but it popped right off. I had the puller like the one shown in the SRB. I will try to remember to take pictures tomorrow.
Chuck C
7 years 3 months ago #173071
by Chuck C
It is all apart but the steering clutch pack. I have to make something to compress the springs
Chuck C
7 years 3 months ago #173091
by drujinin
I made this a long time ago!
Seen as you have all the parts out, you can turn the brake drum up and reassemble all the pieces inside of it to re-align the clutch plate teeth!
Attachment Steering%20Clutch%20Assembly%20Tool%201.JPG not found
Attachment Steering%20Clutch%20Specs.jpg not found
Jeff
7 years 3 months ago #173577
by Chuck C
I started to put my D2 back together but found another problem. The bearing and pin in the bellcrank that releases the steering clutch is shot. They are no longer available from Cat. I have a few calls out there but no response yet. If any one has these parts for sale? 5b-1634 crank,4b-4496 pin and 4b5353 bearing
Chuck C
7 years 3 months ago #173590
by Dozerman51
Florin Tractor in Sacramento, Ca has a 5B-1634 Crank. PH#(916)383-0317. Advanced Machinery Parts in Georgia has a 4B-5353 Bearing PH#(855)876-0804 and Industrial Parts and Equip. in Canada has one also. PH#(306)522-5332.
7 years 3 months ago #173597
Chuck, how many tons did you press the hub on with?
7 years 3 months ago #173599
by STEPHEN
Chuck, I'd ditch that roller bearing system. I had the same problem, what I did is turn a new pin and drilled it for grease from the top( if you ever take the cover plate off). I used a bronze bearing in the arm. My arm was so worn that I bored it to clean up, but just as easily could have used JB Weld in the grooves. The problem with the oem system is that the top of the case there gets condensation and the bearing doesn't get lubed. Haven't had any trouble
D2 steering clutch
Time to create page: 0.193 seconds
