- Thank you received: 680
Better than that Chuck, here's the link to John's D2/933 steering clutch page, which has all the part #s. But I'd recommend just calling him, following up with an email of which parts and qty you need. I picked up both inner and outer hubs, 12 of each disc type, the six pins, 12 keepers, 6 of each spring type, and a brake band. That side of my D2 had filled with water.... The other side doesn't appear to have so hopefully when I pull that apart, I won't have to replace as many partsNeil, could you please give me all the part numbers for the clutches and drum and John's contact info. I have been following your thread and the only real problem I had taking my D2 apart was the cap that holds the pivot shaft to the final drive case. Everything came apart fairly easy. I have a friend (retired mechanic) that says he has all the Cat tooling to pull the steering clutch and the outer drum.
Chuck C
Is that Pacific time or Eastern? ha, lolI think I can see in your picture two puller holes, which should be threaded. I believe they're at about 2 o'clock and 8 o'clock in your pictures. That's where they should be anyway.
Pete.
support@acmoc.org
- Chris R
- Jason N
