D2 going in the shop
Thank you received: 236
4 years 9 months ago #212530
by d2gary
Just wanted to let anyone that is designing a canopy know that I used 56 feet of tube for my canopy. Sounds like a lot but it adds up pretty quickly
4 years 9 months ago #212758
by d2gary
Took the plunge and started hacking off the old mounts on the blade. I'm going to try and put the cylinder mounts on fashioned after the Cat style 2s blade . The cutting edge is going to need a little attention also. I tried cutting some of the rotten metal away but to much rust and dirt for the torch. I have a cutting wheel for the big grinder to cut that section to see what's going on in there.
I also did a little straightening on the top of the blade, it's not perfect but not to bad for what I'm doing and I still have a lot of cutting and welding to do so we'll see how it works out.
4 years 9 months ago #212789
by d2gary
Was able to get the first layer cut off with the cutting wheel and the torch. I ran out of oxygen so I'll be cutting some more off to get back to some good metal when I get more oxygen.
Did a little work on getting the cylinder mounts on. Did a quick check to make sure the spring cover will still fit and doesn't seem to interfere with the cover
4 years 9 months ago #212906
by d2gary
Got all the old metal cut back to something pretty clean and got some new metal welded in.
4 years 8 months ago #212984
by d2gary
Had to do a little reengineering , the last mounts for this blade were really wide. After looking at my d4 cat blades I decided that to mimic the cat blade I would have to narrow the blade. I didn't want to cobble something in to make it work so this was the best option. Really wasn't that bad, a couple of hours cutting and welding. I might plate some of the joints but I'm confident this is a good weld
Thank you received: 10
4 years 8 months ago #212994
by ccjersey
You’ve done the trick on that dozer blade! Will you install a bolt on cutting edge? Maybe weld one on?
Dlyman55
4 years 8 months ago #212997
by d2gary
It will be a bolt on cutting edge. My welder friend has a big plasma table and buys whole sheets of AR plate and can cut the square holes and the cutter very economically.
Thank you received: 78
4 years 8 months ago #213011
by bernie
d2gary-Your posts, this one included, provide a lot of good info. Just as an example, I think this Is one of only a few detailing a dozer rehab. Thanks for taking the time to share.
Have fun,
Bernie
4 years 8 months ago #213409
by d2gary
Have fun,
Bernie
Thank you, I appreciate that. I've got so much help from everyone in this club I hope I can give a little back.
4 years 8 months ago #213508
by d2gary
Got some work done on the push arm mounts. Nothing real hi tech but I've seen a lot worse last for a long time.
Cutter edge and cylinder mounts will be next. I'm getting close to finishing the major fabrication. Paint and final assembly not to far off!!!
Time to create page: 0.488 seconds
