- Thank you received: 929
The top link on 3PL shouldnt be parallel with the link arms the linkage wont work correctly if it is as no traction will be gained it is just like hooking onto the piece the draw bar slides side to side on it gives no transfer of load and in fact will decrease traction
The top link should be set to supply the traction you need by adjusting weight transfer towards the front or the rear of the tractor as required
the more you want to transfer the steeper the top link should be the less load you want to transfer the link should point further to the lower front of the machine
and under no circumstance should the top link be anywhere near parallel to the ground when working no matter what you have on the linkage as it will make it unstable
So in a long winded way the top link shouldnt be parallel with the lower links unless may you have a linkage mounted spray tank and the jets need to be at a certain angle to the ground
this applies equally to wheeled and tracked tractors all to often I see poorly designed 3PL set ups on crawler tractors that make the tractor more unsafe than people can expect and it is solely due to people not having a good under standing of how 3PL and load transfer has to be set up
Paul
support@acmoc.org
- Chris R
- Jason N
