Cat d6b 37a
Cat d6b 37a
Thank you received: 5
2 years 8 months ago - 2 years 8 months ago #236371
by robclay
Got the oil cooler off. Nothing obvious stands out. It looks pretty good. I washed the inside out with brake cleaner and nothing came out, but... brake cleaner. I really couldn't think of an easy way to test if it's clogged. But I filled it up with oil and it took oil real slow. After I filled her up and stood upright the oil just trickled out. Not sure if that's a sign of a clogged cooler, but seems like it would cause some flow issues. The service manual says the oil cooler is bypassed until the engine warms up and then a valve in filter housing shuts and redirects to the oil cooler. Got me thinking I might just replace it. Hate throwing parts at a machine, but I sure don't want to run it this way.
Last edit: 2 years 8 months ago by
robclay.
Thank you received: 788
2 years 8 months ago #236398
drain it and clean off the oil and soak it in a bucket of kerosene, diesel or solvent based degreaser for a few days see what happens it will have oil and coolant galleries. might be a idea to take it to a engine reco shop and get it bathed in the hot tank to try and disolve any crud inside.
2 years 8 months ago #236418
by robclay
Good idea. I did order an aftermarket one. I'll check it out when I get it. I'll soak this one in solvent and see if it cleans up.
Fat Dan
Thank you received: 10
2 years 8 months ago #236723
by Mr Adams
Hello
New member here
I have just purchased a D6b not running was told there was engine damage
Iam looking for information on the machine
Year, type of engine
Serial number 44a10066
Thx
Thank you received: 185
2 years 7 months ago - 2 years 7 months ago #236798
by Fat Dan
Welcome ..1965 74"gauge
ACMOC Member
Last edit: 2 years 7 months ago by
Fat Dan.
Thank you received: 418
2 years 7 months ago #236865
by Deebo
Hello
New member here
Thx
There's a couple of manuals in the Tech Library might help. More being added all the time. Search for 44A. Parts catalog not quite up to your serial number but I’m sure it’d help.
Fat Dan
Cat d6b 37a
