22 pumps
22 pumps
Thank you received: 240
9 years 9 months ago #117854
by Mike Meyer
Very interesting history lesson there Mike, thanks for taking the time to share it, I just added 2 photo's for the discussion including that poorly designed pull rod you mentioned and the new one way valve just made by my Fitter and Turner neighbor to solve my problem but I think you will come up with a better design.
Did you get a chance to measure those one way valve discs while you had Ray's pump in the shop, I need to grab 3 sets of spares.
Regards
Mike.
9 years 9 months ago #117872
by Mike-Casella
Mike, Ray's pump was different than yours. His was one of the cast aluminum AC pumps having different valves. As soon as I can get thru the snow drifts that are blocking the back building, I'll see if we might have one of the types of castings that you have so I can get the sizes from.
9 years 9 months ago #117975
by 22runner
Mike I have a number of 22 fuel pumps to repair I need a web site or contact Info Thank you. Tom [22 runner]
9 years 9 months ago #117982
by Mike Meyer
Hi Tom, I use email to contact Mike, he said the other day their website is down, broken crankshaft or bigend, something like that, use <a href="This email address is being protected from spambots. You need JavaScript enabled to view it." target="_blank">This email address is being protected from spambots. You need JavaScript enabled to view it. I'm sure Mike will come back with a phone number, I have found him very good to deal with.
Regards
Mike
Thank you received: 6
9 years 9 months ago #117986
by puffer@rpi.edu
Tom, You can call Mike Casela. He will tell you to mail the pumps to him. He will then repair them and call you with the cost. You give him your credit card number and he ships the pumps to you. For my pump the cost was $95 plus shipping. I am very satisfied with their service. Ray
Then and Now Automotive
Address: 447 Washington St, Weymouth, MA 02188
Phone:(781) 335-8860
Thank you received: 9
9 years 9 months ago #118053
by pbamburak
Hello, All,
I have been working on a 22 fuel pump as well and mine is the same as Mike Meyer's with the sheet metal pull rod and same one way valve. Mike - I can't tell from the photo but it looks like your friend machined a complete new one way valve to fit the brass nut. In the attached photo is a one way valve that I sourced from a antique auto parts company and with a little machining of the brass nut it look like it will be able to do the job.
Paul Bamburak
Trenton, NJ
9 years 9 months ago #118054
by Mike Meyer
Hi Paul, that is exactly what I was looking for, are you able to get some more of those, because yes, my neighbor made a complete valve from scratch, well actually 2 of them, it was a fair bit of mucking around and took a few hours all up as there is not much metal to play with there.
Well done Paul, I knew there had to be a suitable valve in the USA somewhere.
Regards
Mike
9 years 9 months ago #118057
by D349
G'day Mike. If the valve is 3/4" in diameter the number you need is 1P2298, used in lots of fuel pumps in 70s and 80s. Cat used a slightly bigger one ( approx. 1") in later stuff but I don't have one to measure.
Kevin
Thank you received: 276
9 years 9 months ago #118079
by rax200
Kevin
Mike/Kevin, the part number changes to 7E5346 and are avaliable in Clayton for $4.04 +gst
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
9 years 9 months ago #118082
by Mike Meyer
Thanks Daryl, I just checked Cavpower in Adelaide, their price is $2.91 for 7E5346, but unfortunately it is too small for the 22 fuel pump, we need the 1" valve.
Regards
Mike
22 pumps
Time to create page: 0.207 seconds
