new member with a 1935 Cat 22
Thank you received: 6
12 years 3 months ago #67579
by ol Grump
LCM, Check your local NAPA store for that button head adapter fitting. To make sure ya get the right one, take one of the fittings out and take it with ya when ya go.
12 years 3 months ago #67590
by lil cat mec
more good ideas lol... i don't know why i didn't think about any of those but thank you
1935 CAT 22 2f4455W
CAT 951
Thank you received: 25
12 years 3 months ago #67610
by daron
"but what about the pressure? couldn't it blow the seals?"
There are no seals on your button head lubed bearings. They're supposed to be 'over lubed' (push dirt, etc. on out) ~every 10 hours.
Daron
12 years 3 months ago #67645
by lil cat mec
sweet!!! that keeps my wallet a little thicker lol!!! knowing i dont have to get the special gun!!!!
so oil pressure, im getting about 18lbs is that high enough or is that low?
1935 CAT 22 2f4455W
CAT 951
12 years 3 months ago #67683
by lil cat mec
so another problem... what i beleieve are the fill plugs the big roundbolts with very large hex ends, if these are correct for the transmition and finals, how do i remove these? adn i am still trying to figure out if 18lbs is enough
1935 CAT 22 2f4455W
CAT 951
Thank you received: 342
12 years 3 months ago #67684
by edb
Hi LCM,
your machine uses a 6B2355 gauge by my parts book.
Scanned below is an article on an updated gauge for all machines listed in the scan.
The6B2355 gauge shows the "Operating Range" lube pressure as being between 10 and 40 PSI.
The updated gauge shows "Operating Range" lube pressure as being between 4 and 11 PSI before the gauge pegs out at full scale reading.
From this we can see that 18 PSI would be well within the "Operating Range" and therefore safe to operate.
Your 22 engine is a big low RPM low stressed engine with large bearing areas to work safely at low oil pressures.
By the article you can see that the higher stressed D2 thru to D8 Diesel engines of the day worked safely at these pressures--and with the same gauges.
In reality these engines only need a supply of oil to safely operate due to the large bearing areas they have been designed with. If the bearings were small like an auto engine they would need higher pressures to last.
I feel 18 PSI is a safe pressure to operate at.
The reason Cat fitted these style gauges was so that people only needed to see that their engines' oil pressure was within the "Operating Range"
As you have found, you see 18 PSI, and think there is a problem, BUT, in reality there is not one for these style engines. They operate at low RPM's, unlike an auto engine.
The plugs with the big hex. cups can be undone with a tool made from a nut or bolt head.
Cat do sell the tooling but if you do a "search" here you should find where people have shown how they made suitable tools for the job real cheap. They welded a suitable sized nut or bolt to a piece of flat steel and did the job.
Hope this helps.
12 years 3 months ago #67685
by lil cat mec
okay thankyou... i was wondering if it was forsure the fill caps before i make a wrench just to figure out its the wrong one lol... and my guage is not the same as either in the picture but as it shows the highest "minimum operating range" is 10 and im pretty sure 18 would be fine for mine as you have explained... THANKYOU!!!
1935 CAT 22 2f4455W
CAT 951
12 years 3 months ago #67686
by edb
Hi LCM,
copy/save this lube chart while it is still up, paste the two pieces together to form the full chart, and file it away for future reference.
The Chart is from my grey covered 22 Tractor Operator's Instruction Book, Form No 4313. Maybe keep an eye on ebay for one.
With regards your Oil Pressure Gauge reading, it is not unknown for gauges to read incorrectly.
If you have another gauge of known accuracy you can double check your actual Oil Pressure with it and be sure of what you have, or, at least check against the other gauge.
Hope this helps.
12 years 3 months ago #67711
by lil cat mec
Thankyou... and i went to grainger and they had a button head coupler 7/8 and it was only $25 after tax, sure beats napa wanting $40 + tax!!!
1935 CAT 22 2f4455W
CAT 951
12 years 3 months ago #67727
by lil cat mec
well i made a wrench for the fill plugs
it took about 2mins to make... lol... and i pulled all of the plugs and the left final was full and brownish, the right was about 3/4 full and black and the tranny had about 2 or 3 drops... so im planning on getting a couple gallons of deisel, but my one question is how long should i run it??? i need to clean all of the cases out...
1935 CAT 22 2f4455W
CAT 951
Time to create page: 0.307 seconds
