new member with a 1935 Cat 22
12 years 3 months ago #67523
by zootownjeepguy
Drain plugs will be on the Bottom. Fill plugs just above the bottom, somewhere.
Rich Salvaggio
D2 5U9917
The 2 most useful tools to have in your shop are a Crystal Ball...
12 years 3 months ago #67525
by lil cat mec
okay the question i ment to say mr.smarty pants lol is do i fill to the bottom of the fill plugs? and with the finals what is the aprox amount of fluid they hold? and also what about lubing the rollers??? how do you do that???
1935 CAT 22 2f4455W
CAT 951
12 years 3 months ago #67530
by zootownjeepguy
Yes, fill until oil comes out of the Fill plug holes. Oil capacities will be in the manual, anywhere from a couple quarts to a few gallons. These old things hold LOT'S of oil in MANY different places, just to warn you.
Rollers are greased with a special pump called a "Volume Compressor". Basically, it's just a big grease gun made by Alemite. The "track gun" as they are sometimes called had a chuck to fit onto a special grease fitting called a "button head" fitting. A standard, everyday, ordinary grease gun will also work if you have the special chuck-adapter for the fittings on the rollers. Sometimes people convert the old Cat's to regular Zerk type grease fittings but it takes longer to pump grease through the smaller zerk fittings. There's a link (courtesy of Bumpus) on the For Sale side of the BB for a Volume Compressor that D4 Harry has on Fee-Bay now, if you want to see what one looks like.
You can call me "Mr. Smarty Pants SIR"
Rich Salvaggio
D2 5U9917
12 years 3 months ago #67553
by zootownjeepguy
My bad, it was posted by Harry Brandt himself (not Bumpus). Look on the For Sale/Wanted page for "I have a few more cat parts on ebay".
If you don't like calling me "SIR", you can call me "your Majesty"
Rich Salvaggio
D2 5U9917
12 years 3 months ago #67565
by Soapy
The Alemite "big button" adapter fittings are available from McMaster-Carr, about $40.00 They have a 1/8" female pipe fitting on them so they can be attached to your grease gun. There are two different sizes, so be sure and get the Big Button one.
12 years 3 months ago #67571
by Soapy
LCM,
Use a manual lever type grease gun, and you can feel when the bearings or bushings are properly greased.
12 years 3 months ago #67572
by lil cat mec
and the adapter fitting goes on the grease gun right? i have a couple sources around here that may have one but if they don't then it looks like i will be buying one
1935 CAT 22 2f4455W
CAT 951
12 years 3 months ago #67574
by drujinin
the reason im asking is how little my clutch moves... here are the pics again!!!
im not touching the clutch pedal yet and the yoke is supposed to go towards the flywheel, in otherwords there is only about 1/2 an inch of movement before it hits the pressure plate!!!
another imporntant thing
the man who replaced the clutch put the wrong throwout bearing in it, it is to narrow... the inside dimater and outside are good it is just too thin so there is motion in the bearing case and on the shaft so the clutch isnt starting to disengage as soon as it should... so i am in need of the throwout bearing... im hoping i can get it from western states(our local CAT dealer and mechanic shop) am i right that the bearing number is 10+009??? thats what it looks like on my copy of the parts manual
You should be able to look through this Parts Manual that you quoted above and see where the fill and drain plugs are. Of course it will not give you capacities of said compartments. You should also be able to look at the Magneto section and figure out which Magneto you have to find the shorting screw/stud for a Kill/Stop wire to connect to.
Time to create page: 0.365 seconds
