d3400 electric set
13 years 8 months ago #58929 by deannis
d3400 electric set was created by deannis
Hi all old junk enthusiest like myself, I recently aquired A D3400 I think electric set. Both the tag on the engine and gen are missing, but where the tag should be on engine the block is stamped 859. On the gen. end it says 110/220 37.5 kva 30kl1480 6b6428 this also is stamped into generator housing and you can see there was A tag rivited over this spot. There is A external belt driven exciter mounted directly above unit. I believe this to be A d3400 engine, later model, but am unsure. I have an early D2 ser 3j1801, which looks very similar other than exhaust around intake oil filter and a few other changes i have found through internet serches. I was born in 1963, so theese machines are before me, but I love antiques, and have many. I bought theese two machines at an estate sale, the dozer which had sat for nearly 10 years is running well after filters and fuel tank flush, great undercariage and clutches,all of them, and a blade and canopy,all for a grand. This machine was restored in 1981,have reciepts for a lot of parts, crank grind,making new bushings for pony rods small ends, cluch parts ,rad. but no liners or pistons, anyways machine performs well. Also at this sale was this electric set, $200.00 scrap price, I said yes. Got it home ysterday,full of oil,full of antifreeze,junk pony motor. I am already looking at electric conversion from one source on the net. I am a diesel mechanic by trade and am competant that this thing will run, or so I hope, Iwould like some history on this thing or any information would greatly be appreciated. Also,shows 1612 hours on hour meter,and I bet it still works.
13 years 8 months ago #58934 by Old Magnet
Replied by Old Magnet on topic d3400 electric set
Those pictures are a little fuzzy on my screen but I believe you have a D4400 there.
If the fuel transfer pump is on the bottom of the filter housing it's the D4400 for sure.
13 years 8 months ago #58935 by Pioneer1930
Replied by Pioneer1930 on topic d3400 electric set
I am mad jealous. A smaller Cat gen-set is my next planned project, good for you on such a great deal! Good luck with it!!!!:thumb:
13 years 8 months ago #58936 by drujinin
Replied by drujinin on topic d3400 electric set
OM might be right as I am rereading this and thinking 37.5kva times 0.8 equals 30kw. I believe most D3400 gensets are 25kw. still a GREAT find though as it seems to be 110/220 which means in all probability that it is a single phase generator not a three phase which is what most generally shows up..
13 years 8 months ago #58937 by Sasquatch
Replied by Sasquatch on topic d3400 electric set
OM's correct, it's definitely a D4400. The flat plates on the side of the block that hold the decompression levers are a dead giveaway.
13 years 8 months ago #58943 by B4D2
Replied by B4D2 on topic d3400 electric set
Welcome to the forum. You have found the a great source for information. Both acquisitions are commendable. The machinery looks to be in good shape, but the price you paid puts you in the "positive" column as far as equity is concerned. Great finds.
13 years 8 months ago #58945 by snowshoveler
Replied by snowshoveler on topic d3400 electric set
Yup sure looks like the 4400 to me...the governor in its squared off case is my clue.
But Old Magnet seldom if ever makes a mistake so I side with him.
More pics in greater detail would be appreciated.
Regards Chris
193? d4400 cat powerunit
1950 john deere M
1959 international t5 crawler
1977 powerking 1216 tractor
13 years 8 months ago #58967 by deannis
Replied by deannis on topic d3400 electric set
Hi everyone,thanks for the info,I will take better pictures tomorrow. The pictures posted were taken with A cell phone. I really want to get this thing fired up. Contacted pony motor conversions todat, a little steap on prices but, the pony motor conversion makes sense to me because i could always use it on the d2.Anyways I will get better pictures,just have to get the other half to do it for me,huh. Thanks Dean
13 years 8 months ago #58968 by deannis
Yes the fuel transfer pump is mounted on the bottom, unlike the d2 3j1801, which is mounted horizontally. So what is A d4400? H.P. I am assuming this thing runs at 1200 rpm? I will also send pictures of A 49-50 Nordberg 10 hp that is almost done. Also anybody interested in A 8 or 16 hp sheppard diesel, how about A 2 cyl. Hercules diesel, unknown vintage, probably 8-12 hp. will also post pics. Thanks
13 years 8 months ago #58979 by Old Magnet
The D4400 is a 4-1/4" bore vs the 3-3/4" D3400. Most commonly known in the D4 tractor and 112 motor graders. Replaced by the D315 in 1947 with 4-1/2" bore.
In 1200 rpm generator applications H.P. ranged from 34 -44 depending on set up.
Is there provision to mount a direct start on the clutch housing. Some early industrial applications have the hole already provided making conversion pretty simple.
You can do your own conversion...found in these instructions.
sites.google.com/site/oldmagcat/
Time to create page: 0.188 seconds
