- Thank you received: 1
Nothing wrong with heating/cooling the inside, it's those expansion-shrinking cycles that are needed to break the bond. How hot are you heating the nut, usually takes dull red heat to do any good. Don't get to carried away or you may weld/gaul the threads. I would also not advise doing any quenching as you will wind up changing the metallurgy. No press huh??
Forgot: The press frame I have will handle 100Ton but so far I only own a 50 Ton ram. As I recall it was in the 40-50 ton range to hold it from turning.
OZ, I am located pretty rural, no one close that sells dry ice. I am keeping it in mind though as I may try that at some point if I don' t get something else to work first.
I plan on attacking it again today.
Thanks - dd
support@acmoc.org
- Chris R
- Jason N
