Cat D4D 7R503 Blade Parts
16 years 2 weeks ago #22753
by ceo-cdr
Hello Old Magnet, i received photos af the part number you quoted me and the assembly doe NOT have the eye-bolt with it, would i have to order that separately as i need the whole piece?
16 years 2 weeks ago #22755
by ceo-cdr
Are there any manuals that i could pick up that would give me the parts lists for my blade assembly? I have the Jensales Operators, Service and Parts manuals but none of them have any blade information in them. (either that or i am orverlooking it) I do NOT have the tag off the blade as i tried to uncover it with paint stripper and a rag, as suggested earlier, and all i ended up doing was disintegrating the tag when the paint was removed. I really apprediate all of you help and expertise. Thank you, Dave.
Thank you received: 820
16 years 2 weeks ago #22756
The eye bolt is a separate number so I guess it is not part of the assembly.
Really need a blade serial number to match you tractor. Especially since it is a wider gage unit. Was there no number stamped under the tag location?
A lot of parts are interchangeable between units of that era.
The closest I have info on is attached:
This is one of three variations.....I can't tell from your picture which tilt brace style you have to help with identification but all use the same lower diagonal brace.
16 years 2 weeks ago #22773
by ceo-cdr
the tag on the blade was just a sticker, no plate. there was nothing stamped under the sticker. there are no other plates on the blade. the tilt brace on the left is solid, no adjustment, with a tilt cylinder on the right.
16 years 2 weeks ago #22775
OK, that's correct, the rigid brace is an attachment that goes along with the tilt cylinder arrangement.
Don't know what to tell you on model # blade......sometimes you can find a part number or casting number on some other parts like cylinders, push arms or the hard nose mounting that would help identify......Cat should be able to help you out if you can get to the right person.
16 years 2 weeks ago #22780
by ceo-cdr
I will look on the push arms and cylinders as i no longer have the original blade. it was too far gone to be repaired and the fab shop just built a new one. Any suggestions as to where to look?
16 years 1 week ago #22914
by ceo-cdr
I worked on removing the broken part this weekend. Unfortunately I had to cut the pin into pieces to get it out. Used part is on order and i hope to have it this week. Will get a new pin made at the fab shop and with a little luck, will be dozing this weekend. Thank you all for your help. Dave.
Time to create page: 0.155 seconds
