Cat D4D 7R503 Blade Parts
16 years 2 weeks ago #22688 by ceo-cdr
I have a Cat D4D 7R503 and i need some parts for my blade. Please bear with me as i do not know all the parts correct names. What I have is a 10ft wide blade with one tilt cylinder on the right side and a rigid brace on the left. What i need is the brace that runs from the left arm to the blade (horizontal to the ground) to keep the blade from racking left to right. The one on the right is ok, but i broke the one on the left this weekend. Can anyone help me? I think I have attached a photo with the part i need circled. Thank you, Dave.
[img]file:///C:/DOCUME%7E1/DAVEMA%7E1.DSM/LOCALS%7E1/Temp/moz-screenshot-4.jpg[/img]
16 years 2 weeks ago #22691 by Old Magnet
You need a Cat # 2J4140 Arm Assembly (same both sides)
or if it's just the eye-bolt that broke a Cat #3F5567
Do a search in the construction equipment parts section of www.machinerytrader.com they have several listed...Regal being one of them, which has good prices on aftermarket parts.
16 years 2 weeks ago #22693 by ceo-cdr
Replied by ceo-cdr on topic Cat D4D 7R503 Blade Parts
Thank you for the information Old Magnet. I need the whole assembly as the one i have has been welded solid by the previous owner and parts are not replaceable on it. the right side is still adjustable.
16 years 2 weeks ago #22705 by d4e
Replied by d4e on topic Cat D4D 7R503 Blade Parts
Looks like a nice LGP D4.It would be nice to see the whole tractor.
16 years 2 weeks ago #22732 by ceo-cdr
As requested, here are some more photos. the first two are of the blade at the fabricators and the others were taken when it got home. Not too bad for an eBay purchase.
16 years 2 weeks ago #22736 by greyhead
Replied by greyhead on topic nice fab job
Looks like the fab shop did you well:cool: VERY CLEAN! nice D4- Always nice to see good craftsmanship!:D
CAT 977K-11K, JD450-B ,JD690-B, IH TD-9 ,CASE 450-B JD750-E JD850-B
CAT D7-3T, KOMATSU P-68-8 LGP, CLARK 55A LOADER
CLARK MICHAGAN 85-C LOADER, CAT V60 FORKLIFT
And some old AC tractors
16 years 2 weeks ago #22737 by Old Magnet
ceo-cdr,
Just as a point of interest the 7R series (low ground pressure - 70 in. gage) were assembled in France (1973).
My sometimes right info source shows the change from the D330 to he 3304 at serial number 434 so you just made it into the better engine series.
That machine is closest to the U.S. built 83J model (powershift) although the 83J is a 60 in. gage.
Shopping for the U.S. equivalent model may have better parts recognition. That's what I had to do to find the blade parts.
Nice looking machine and super blade fab. job.
16 years 2 weeks ago #22745 by ceo-cdr
I have found a couple of places that have the part. Now my question is how do i remove the pin on the blade push arm that seems to be stuck in place? this would be the pin that goes through the eye of the arm assembly and connects it to the main push arm of the blade. I cannot seem to budge that pin, even when i try hitting it with a 10lb maul. I believe it to be rusted in place. Any suggestion? Thank you, Dave.
16 years 2 weeks ago #22747 by Old Magnet
Yes, they can be a bear.
Serious case of heat and beat.....you might want to up size that hammer.
If the pin is shot anyway you might just want to torch it out and replace it.
16 years 2 weeks ago #22748 by ceo-cdr
pin is not shot and seems very solid, just rusted tight in the holes. the bolt to lock the pin in place on the bottom has been broken off. the main pin itself seems intact. very awkward place to swing. can't get much leverage swinging up. I have not tried the heat-n-beat method, yet. when they took the old blade off, they had problems with the push arm pin on this side also. heat-n-beat did not work for them, they had to use a portapower press to get that pin out out. Right side seems fine and is not as snug as the left.
Time to create page: 0.144 seconds
