What was the Cat 22 (2F,1935) original starter motor?
2 months 1 week ago #259695 by Scott Kuehn
I read it was the Delco Remy 736D, but can't find any more information on that.  We're restoring a 2F and had the factory starter, but it the starter missing when we rescued it.  It has the original ring gear, battery box etc.
Any chance anyone out there have any more information on the original starter or where we can find one?
2 months 1 week ago #259700 by josh
Delco Remy 736D is the correct starter.
2 months 1 week ago #259710 by Scott Kuehn
Thanks for the reply. I contacted Delco Remy and explained what we're looking for and they said they didn't have any records of a 736D and their numbers were usually 7 digits. I've tried looking online for anything for a 736D and can't find anything.
2 months 1 week ago #259712 by d2gary
I did a quick search and found this 39mt as a cross reference. I dont know anything more but here's the spec sheet.
2 months 1 week ago #259714 by GrantJ
I suspect that there are other period starters that would work, but getting the correct gear may be the biggest issue. I put a modern starter on my 22, but had to put the correct ring gear on the flywheel so that it matched the modern starter gear.
Good luck and keep us posted on your search. Grant.
2 months 1 week ago #259729 by Old Magnet
Here is the 736D Build Sheet.
The hardest part would be finding the 1850844 Drive Housing.
2 months 1 week ago #259733 by neil
Which catalog number / grouping (truck, car/passenger, etc.) is that page from, OM?
2 months 1 week ago #259734 by Old Magnet
Besides the info in the header it's from my Delco Remy Service Parts catalog, about 8" thick in screw post binder. The kind you used to see on the counter of old time parts departments.
2 months 1 week ago - 2 months 1 week ago #259737 by Old Magnet
The 39MT starter in SAE #3 arrangement could possibly work but you would need to change to a 10 tooth pinion which I believe is available ( straight tooth in this application).
I haven't done it so you would be beta tester.
Last edit: 2 months 1 week ago by Old Magnet.
2 months 1 week ago - 2 months 1 week ago #259740 by cr
There was an article a while back on the conversation process, including changing over or adding the ring gear.
www.acmoc.org/bb/discussion-d72/15214-ch...t-conversion?start=0
Last edit: 2 months 1 week ago by cr.
Time to create page: 0.218 seconds
