1955 Bucyrus Erie help needed
Thank you received: 74
2 months 2 weeks ago #257844
by D8Dude
That's great news, well done.
If I remember correctly, there was a thread on here a while back that discussed what size socket fitted the nut down inside the lower cannister, I think a custom made deep reach socket does the trick
Thank you received: 113
2 months 2 weeks ago #257847
by PhilC
Oil pump access cover gasket 4F7637
Valve cover gasket 4F7003 and 4F7002 if you remove the spacer between the head and the valve cover.
Oil capacity 5gal
This is taken from a D4 6U1 and up manual which I think would be the same.
K100
Thank you received: 316
2 months 2 weeks ago #257855
by Ray54
Not sure how far apart you are wanting to go. The canister for oil filter just sits on the base has a square section o ring as the gasket. They can be used several times if not disturbed. They get very hard and after years of service will leak. Just tap canister and lift off, dig the rubber out of the grove and put new in. Don't have a number as in the old days they were included with a new filter. So I have a supply tucked away from sun and heat. I believe the top and bottom use the same rubber gasket.
The hex at the bottom of the filter base is a plug to drain the base. It should have a copper washer.
K100
2 months 1 week ago #257869
by K100
Got everything apart and waiting on gaskets and filters now. Does anyone have a source for an electric starter for this engine? It has the place for it. I contacted a number that my local cat dealer gave me for a CC Electric but he wants $600 for a starter. Kind of a high price if you ask me.
1986 Kenworth K100E Aerodyne 3406B Cat 500 HP 13 Speed
1955 Bucyrus Erie 15B D315 Cat
Thank you received: 118
2 months 1 week ago #257870
by willwingo
Attached is the "Capacities" page (back inside cover) for the D 315 engine, Form 10766-2.
If you dump 5 gallons of oil into a D 315 you are going to be a little over full.
2 months 1 week ago #257874
by K100
Thank you for posting. What lubricant goes in the fuel injection housing and the starting engine clutch housing?
2 months 1 week ago - 2 months 1 week ago #257875
by willwingo
They both take "crankcase lubricating oil".
The same as you are running in the main and starting engine.
K100
Thank you received: 779
2 months 1 week ago #257883
600 bucks is what those starters are worth. there not common any more so that equals expensive. you can do direct start conversions. ie mount a starter in the bell housing and start the main engine directly. and still have it pilot start for those freezing cold days or when you run out of fuel and have to bleed it etc. some of the later engines had the dimple on the bell housing to line up a drill and cut the holes others had a cover plate. there is several threads on this forum about doing so.
and dont forget with the canister filters to oil the orings or treat them with a little oring lube it helps em bed in without damage.
2 months 1 week ago #257888
by PhilC
True but if you dump 1/4 qt in the ponies air cleaner, 2 qts in the diesel's air cleaner, 1.5 pints in both the fuel injection pump housing and starting engine clutch housing and 1 qt in the starting engine and 15 qts in the main then you end up with nothing left out of 5 gallons as per the D4 6U parts book. It doesn't split it up like the 315's manual.
K100
The genuine starter from Cat is over $1000.
Time to create page: 0.197 seconds
