1955 Bucyrus Erie help needed
Showing 1 to 10 of 49 results
K100
Send a private message to K100
Greetings everyone. Glad to be a member of this great community.
My name is Jason Deckard from Ellettsville, Indiana.
I've recently acquired a 1955 Bucyrus Erie 15B crawler crane. Transported it 650 miles from Reading Pennsylvania to here in Ellettsville Indiana
I grew up in a junkyard that was ran by my grandfather, and we had a crane similar to this 1955 only it was gas powered. I wanted to get back into my child hood so I bought this one. I am a union electrician but worked on things my whole life.
It is powered by a Cat D315 (Serial number 9S10902) with a pony but has the place for an electric starter also. I need a lot of help with this. The pony is in need of a total rebuild. The exhaust pipe broke off years ago and the rain got into it. It does turn over and feels like its building compression. The magneto (Bosch) looks ok other than the cap having a snapped off electrode.
The diesel engine I think is locked up. I would think I would be able to turn the engine over with a bar on the flywheel through the hole in the bell housing. I believe I had the compression release on but not sure. Going to need some guidance for parts and procedures. I posted some pictures for your viewing pleasure. That's me in green safety shirt checking height after I winched the little dude up on the trailer. Will be waiting for the questions to start rolling in. Thanks again everyone!
Mon, Jun 24, 2024 8:57 PM
Thank you received: 12
Welcome Jason . That looks like a fun machine to play with, and hopefully a whole lot of good memoirs.
A paid membership gets you into the library, with the serviceman's books as well as parts and operator's books. Cat still has a lot of the parts you would need, just some modern parts persons don't want to do the digging. So having a part number transferred into the modern system with enough zeros added helps. But excuse me for not remembering the whole process.
Mon, Jun 24, 2024 10:37 PM
seyser
Jason - Congrats on the 15-B purchase. That is a very nice straight machine! I purchased one last fall and mine has the Caterpillar engine too.
Regarding the potential stuck diesel. You will want to put the decompression lever in the "Start" position as that will be true decompression. Another option for attempting to turn the diesel over would be to engage the pony motor pinion and put a large socket on the pony flywheel nut and see if you can rotate the diesel.
Jeremy
Mon, Jun 24, 2024 10:58 PM
K100
Reply to seyser:
Jeremy
Thanks for the reply. Would like to see some pictures of your machine also.
On the decompression lever, is pulling it away from the engine put it in decompression mode or pushing it in towards the engine? Also, need some direction on the start handle too
Mon, Jun 24, 2024 11:13 PM
seyser
Reply to K100:
Here is mine:
 [attachment=76915]IMG_0748.jpg[/attachment]
Mon, Jun 24, 2024 11:19 PM
seyser
Reply to seyser:
Jeremy
Here is a good video explaining the starting sequence. This is a D2 shown but the procedure will be the same for your D315.
https://www.youtube.com/watch?v=Jcz7qPz8QTE
Mon, Jun 24, 2024 11:37 PM
K100
Reply to seyser:
Great video, thank you. Where would be a source for pony motor parts? I need a magneto cap for the Bosch Magneto
Tue, Jun 25, 2024 12:20 AM
seyser
Reply to seyser:
Jeremy
I have not had to purchase a cap yet so don't know the best place but here is what I found with a quick search. I know Brillman is known as a good vintage wire source and looks like they carry caps too:
https://brillman.com/product/american-bosch-mjk-magneto-cap-for-caterpillar-pony-motors/
Tue, Jun 25, 2024 8:52 PM
K100
OK...update. I was hoping that the main crane clutch was engaged, keeping the diesel from turning over but no such luck. I believe the pinion is already engaged (red circle). If I Push the bigger handle towards the radiator while turning the pony over, it severely drags the pony down but the diesel still doesn't move. I also have the decompression release pulled away from the motor. Am i doing this right?
Tue, Jun 25, 2024 9:11 PM
seyser
Reply to K100:
Yes it appears you are doing things correctly. Good call on verifying the main clutch is disengaged too. These cranes are a little more difficult as you cant just pull it like you could do with a crawler to confirm the engine rotates.
What does the diesel exhaust pipe look like on the roof, Does it have a good flap on it? Might help to determine if water possibly made its way into the engine. Any history from the previous owner on how long it was sitting or condition when last ran?
Tue, Jun 25, 2024 10:40 PM
side-seat
Thank you received: 7
Reply to seyser:
Since the pinion is engaged or stuck, You should disengage it so you can turn the diesel and pony by themselves independently . Since you have a pinion that's exposed you can easily push the jaws that keep it engaged with a screwdriver or whatever works. May need to oil it up so all the parts move freely. Be careful not to get you fingers in the way, there's spring pressure when it snaps out.
If the diesel will turn some, you better pull the valve cover off and verify all the valves will move. If that engine took in water, it went down the exhaust valves.
Wed, Jun 26, 2024 12:07 AM
| Hartley - South Australia
