- Thank you received: 27
Here's a little food for thought.
If you attempt to repair the finals the steering clutches have to come out.
If the bearings bores in the tub are bad you will have to have someone weld and machine them.
you will have to hire someone to press the sprocket and dead axle.
How about you check the transmission filters?
The tracks are on their last leg.
Maybe you should rename your video "how not to buy an old tractor".
Good luck
Bob
Hi Craig -Hi Scott,
Good to see you're making progress on the 977. I'm glad you are able to have such a nice shop to work in. I'm a bit jealous as I never had it so good! Most of my wrenching on my Cats was done in the "Shade Tree Shop"!
The batteries: 4Ds are the best choice, that being said, you can certainly get by with the 31s especially with the local climate.
The right roller frame can be removed with the crossmember attached. I suggest you (carefully!) remove the left side bolts and remove the right side roller frame and get in the open where it is easier to deal with.
Craig
support@acmoc.org
- Chris R
- Jason N
