Hi, hdokes.
A li'l bitta history - the VERY early dozer blades were simply flat plates mounted in front of the tractor. It didn't take long at all for some smart people to 'figger' out that a vertical curve in the blade face would help it to both dig better and carry more material. It didn't take the less smart people long to catch on and copy the smarter ones.
ALL the early dozer blades were fixed straight across the front of the tractor. I suspect that some bright spark watched an angled blade on a pull grader at work and 'figgered' out that it might be a good idea to have a similar arrangement in a dozer blade and so invented the angling dozer blade like yours.
About the same time, give or take, somebody had the bright idea that it might be useful to be able to TILT the blade lower on one side to make it easier to cut ditches or pioneer roads on hill sides and invented the tilt brace to achieve this desired result.. Tilt braces also served another purpose in that, IF you had them on BOTH sides fo the blade, you could tip the blade forward for better digging or back for better carrying capacity.
Whether angled or straight, an angling blade can be titled to one side or the other by adjusting tilt braces. If the blade linkages have little wear, it will need both braces adjusted in opposite directions to get much tilt. If the linkages are worn, you can get some reasonable/workable tilt by adjusting one brace only but that places more load on one brace than the other.
On a STRAIGHT blade like seiscat's, you only need to adjust one brace to TILT the blade but BOTH braces in the same direction to tip the blade forward or back to adjust the angle of the cutting edge for better cutting or to roll the blade back for better carrying capacity. Angle blades do not have much scope for tipping the blade back or forward when new due to having the fixed center angling pivot pin but usually 'gain' some scope for that as they wear. The FIRST bulldozer:
To clarify, "Cutting angle" is usually a reference to the 'tip' forward or back of the blade face. 'Tilt' usually refers to having one side of the blade lower or higher than the other. "Angle" usually refers to the blade being angled across the line of travel to drift the material to one side or the other.
A 2-way blade, a VERY rare beast these days, would only have up-n-down adjustment. A 4-way blade has up-n-down and side-to-side TILT adjustment. A 6-way blade has up-n-down, tilt and angle adjustment - - - NONE of which are available on the image above.
The above 'ranting' should make it about as clear as mud for you.
Although a little more 'long-winded', I hope this makes things a little more clear for you than trainzkid88's earlier post.
