New Member
1 year 1 month ago #251593 by JoeMoad
Replied by JoeMoad on topic New Member
They are thick forest in places. Mainly 10-13 feet tall, big trunks. There are some that are 20-30 feet tall. They have been growing on Ranch for 45-50 years as ranch was leased out. I took it back officially in 2016. Got a contract to clear them last year. I have been using my 240LX Link Belt excavator and it does a great job. But need this dozer to speed up the project alot faster. Thanks for asking!
Joe Moad
1 year 1 month ago #251594 by Kurt Bangert
Replied by Kurt Bangert on topic New Member
Joe! Welcome aboard, glad to have you. Make sure to post photos, we all like photos!
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
1 year 1 month ago #251595 by JoeMoad
Thanks Kurt i will definately fill everyone in on new happenings.
Thanks!
Joe Moad
1 year 1 month ago #251596 by Deas Plant.
Replied by Deas Plant. on topic New Member
Hi, JoeMoad.
The couple that I have seen were welded and plated - inside and outside. The cause apparently was the heavier blade hanging off the nose. I believe that, later in the model run, Cat beefed up the frame rails around that area. I don't have the serial # for that modification.
If yours has the hydraulic ripper pin puller, it doesn't hurt actuate it once in a while. It doesn't need to run the full stroke, just 2 - 3" or so to make sure it is free and then close back in.
I don't know what your thoughts are on decelerating when changing direction but I ALWAYS do.
1 year 1 month ago #251599 by Rome K/G
Replied by Rome K/G on topic New Member
Here's what you need to clear, but you have to know how to use them.
www.jmwood.com/ROME-206-KG-BLADE-FIT-CAT-D9G-D9H-B-6_i32864557
1 year 1 month ago #251600 by JoeMoad
Thanks again Deas Plant. I have a mechanic checking out the whole machine Monday and i have given him advice to check that bar for cracks. Also the hydraulic pin puller.
Thanks a million!!
Joe Moad
1 year 1 month ago #251601 by JoeMoad
Thanks for the blade info. I have found a real heavy brush rake that fits on the U Blade. I like your idea of the smaller blade with the push bar on top. Thats kinda what i was looking for. (I have seen many types of brush blades, rakes, etc) Since i have been looking for one i found this rake and thought it would be easier to use since it mounts to the blade and tilts back when baclking up. In other words it only works when going forward or pushing so as to not tear up more un needed soil. I will post a pic of it for you decide what you think of it?
Joe Moad
1 year 1 month ago #251604 by trainzkid88
Replied by trainzkid88 on topic New Member
ive seen stick rakes that were made so you hang them on. the blade the blade itself sat in a recess in the rake the advantage with that is you can easily remove the rake to do other jobs when not pushing timber. it also gave a wider pass width. and being removable easily is better transport wise(less oversize restrictions)
1 year 1 month ago #251606 by JoeMoad
Hey Trainzkid:
Thank you for chipping in on my setup to wipe out the trees. I cant figure how to post pics on this forum. I have a couple real good pics that i wish you could see. It is about 15 ft wide and built stronger than anything i have seen. Holt Cat in SanAntonio built it years ago and i dont think a 20” steel conductor pipe sticking up would phase it, much less the trees i am going after. I was busy doing paperwork and missed your post, sorry for the late reply. Let me know how to post pics from my library on my phone and i will get them on here. Sorry finally figured how to use the editor.
Thanks Again and enjoy your Sunday!!
Joe Moad
Oklahoma
Joe Moad
1 year 1 month ago #251607 by Deas Plant.
Hi, JoeMoad.
Nope! These are RAKES.
www.gessner.com.au/products/dozer-stick-rakes-tree-spears/
LOL.
But, seriously, a good operator with a normal blade will likely pile up cleared vegetation with less dirt in the heaps than a bad operator with a rake. Even with a rake, most times you can't just push straight to the heap, You need to roll the gathered wood in front of the blade or rake to shake any collected dirt out of it. The more gathered wood in front of the blade or rake, the more it will gouge into the dirt and contaminate the load. Funny things is, bigger logs tend to do this less than lighter trees, saplings and brush 'coz there is more space in the load for the dirt to fall out.
That rake looks like it could do the job but I think you will need to just skim the ground most of the time as those tines are not long enough rake through the ground and still have the dirt fall away.
Time to create page: 0.201 seconds
