1954 D2 5U
1 year 2 months ago #251382 by mc
Replied by mc on topic 1954 D2 5U
Yes to a tear down and rebuild of the pinion. The 4 bolts that hold the what-cha-dingy to the pinion gear were gone. found one of them in the bottom of the case. Your right, I do not want to do this again because I did not pay attention to something. Never be any closer or easier to repair. Will evaluate clutch disc also. Seems to have only about 1/16 inch proud above tooth center. Not sure what new is.
thanks
marc
Pembroke, NH
1 year 2 months ago #251405 by cantmetal
Replied by cantmetal on topic 1954 D2 5U
I just rebuilt the start pinion clutch assembly on my D4 7U, working on getting a video up - helpful tip is soak it in vinear for a few days. For me, worked really well and much cheaper than evaporust
1951 D4-7U
1 year 2 months ago #251406 by neil
Replied by neil on topic 1954 D2 5U
Vinegar eh? That's another option to the "usual" acids that people use like citric and such. You just need to sneak it out of the kitchen without getting caught : )
1 year 2 months ago #251425 by juiceman
Replied by juiceman on topic 1954 D2 5U
I have cleaned parts before using vinegar. It is better when a person can get their hands on something stronger than 5 "grain" vinegar, which was the norm for household use.
Vinegar strength is measured in "grains", just as your favorite hootch is in "proof". If you're feet ache from standing all day wrenching on your iron, soaking your feet in hot water with apple cider vinegar is not only soothing, but good for you. Nice and tingly too.
Cleaning parts without the chemical smells or worrying about hazards using ACV is great too.
I should see about buying a drum of the "good" stuff from somewhere. JM
1 year 2 months ago #251427 by Mike Hudson
Replied by Mike Hudson on topic 1954 D2 5U
Good Friday morning all. This topic interests me because I own a D 2 4U5401X 1952 model. Grinds reall bad on start up and I need to fix that. I just don’t know where to begin, Split the tractor? Remove the pony? I know it’s necessary to gain access to the pony clutch. I flushed it with kerosene and didn’t help. I’m new here so please allow me to serve y’all. I will not lead anybody wrong. This machine is new to me. Thanks a million
1 year 2 months ago #251430 by trainzkid88
Replied by trainzkid88 on topic 1954 D2 5U
mike that should really be its own topic but ill be brief.
the pinion clutch mechanism also has a clutch brake.
to apply it you hold the clutch lever in the disengaged position as far as it will go this stops the pinion turning so you can engage it smoothly with out damage. try that first.
if the mech is worn and not kept adjusted and rebuilt with new wear part as needed it doest work and it damages the fly wheel and pinion gears.
get a copy of the serviceman reference for your machine. the owners maintenance instruction and parts book/s are also useful(each attachment has it own book)
yes the pilot engine has to be lifted so you can get the pinion shaft out to repair it. get a boroscope and remove the inspection cover for the clutch/flywheel housing and inspect the ring rear for damage before removing the pinion set up. this will help show how big the job needs to be.
1 year 2 months ago #251473 by Texasbest
Replied by Texasbest on topic 1954 D2 5U
Mix some water softener pellets with the vinegar, soak your parts in it and give it a few days and it really works.
Make sure to neutralize it when you wash it off.
1 year 2 months ago #251474 by GrantJ
Replied by GrantJ on topic 1954 D2 5U
Be careful of vinegar stronger than 5%. I just attended a class on herbicides and of the many discussed, 20% vinegar was the most dangerous for the user. Full hazmat suits and eye protection were required. I have used the 5% many times and was surprised that the stronger stuff was so dangerous.
1 year 2 months ago #251476 by D4Jim
Replied by D4Jim on topic 1954 D2 5U
The 20% and up concentrations are very caustic and particularly damaging to the eyes. Wasn't aware of the hazmat suit requirement but one sure has to avoid skin and contact with the eyes minimum of goggles, rubber gloves, and long sleeved clothing. The 20% will start to burn the skin after a few minutes of contact. (from experience) I never really read about it's toxicity but figured to treat it similar to CLR.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
1 year 1 month ago #251485 by Mike Hudson
Hey Grant. Sounds like a great suggestion but how do you neutralize it. I’m thinking maybe pour coke cola on it But I’ll bet you just flush it with water. I’m thinking of cleaning pony motor clutches with it. Thank you
