1954 D2 5U
1 year 2 months ago #251327 by mc
1954 D2 5U was created by mc
marc here again, jammed up here in NH, USA. trying to get to the flywheel and ring gear to replace the ring gear through the access hole for the clutch. have the flywheel unbolted but there seem to be a geometry problem betting it out that way. Please don't tell me i have to pull the engine!!
please advise.
marc
1 year 2 months ago #251337 by neil
Replied by neil on topic 1954 D2 5U
If your serial # is less than 5U13273, then you have to remove the engine to remove the flywheel. If it is above, I'm still not sure if the flywheel can be removed - certainly the clutch can be changed out but the flywheel is a larger diameter. Someone here will know
1 year 2 months ago #251346 by side-seat
Replied by side-seat on topic 1954 D2 5U
Did you remove the entire clutch cover casting? You have to pull the pony flywheel and firewall to get to all of the bell housing bolts to do so. Pictures Please.
On your other post about the gear jamming up at the same spot; Did you look for a chunk of rust clogging a tooth? Alot of times from the tractor sitting outside ,water gets into the clutch compartment and the gear sitting in the water and other crap it gets rusted.
1 year 2 months ago #251358 by mc
Replied by mc on topic 1954 D2 5U
I successfully pulled the flywheel out the clutch access hole!!!! You would not believe how tight that was, unbelievable. Had to pull the starter pinion, lift the starter motor up. the space the pinion remove gave was just enough to cock the flywheel out with a little bar action. The clunk was missing teeth on the ring gear. How does someone do that? See picture. now I need a ring gear which seems hard to find. The confirmed part no of the ring and book is 7B6248.
Marc
Pembroke, NH
1 year 2 months ago #251360 by mc
forgot picture.
1 year 2 months ago #251361 by side-seat
YOWSA!   I see now. Grind me a pound.    Yeah they're a little tricky to maneuver. But lighter than others.
1 year 2 months ago #251362 by Rome K/G
Replied by Rome K/G on topic 1954 D2 5U
That's that under your skin grinding racket when owners are too damn lazy to fix the brake and pinion!
1 year 2 months ago #251364 by neil
General Gear had a new one for my 5U, had to finesse the bolt holes a little but otherwise bolted right up
1 year 2 months ago #251369 by mc
thanks, i will try them.
marc
1 year 2 months ago #251378 by trainzkid88
Replied by trainzkid88 on topic 1954 D2 5U
might be a idea to fix the starter pinion too. while its off its part way there. becuase i would put money on it being damaged/worn too. at least crack test it make sure it right dont want to do the same job again.
Time to create page: 0.184 seconds
