CAT-CAVE Order to Cat INC Inlet Manifolds for Restoration CAT USA HQ Projects
Thank you received: 775
1 year 3 weeks ago #250511
i did enquire about a decal kit from the club a few yrs back. and it was fairly reasonable. i would have to get a custom plaque made for ours as it is no longer original when it comes to the starting engine im currently converting it to a more modern diesel pilot engine which will have the choice of pull start or electric start.
the filler bowl I'm looking for is part no:1A559. apparently it was common on machines set up as dozers for these to get damaged by rocks, logs, tree stumps etc which is what happened to ours as the cousins used her for snigging logs as they were sleeper cutters. when they broke one they broke one they removed them both and put normal bungs in place instead.
Thank you received: 101
1 year 1 week ago #250891
by Catman
Cat3600. I received your Private Message a week ago. I did reply back to you.?
Yes. Cat-Cave is re-running Previous Manifold Projects. CAT 20 8C, Cat 20 , Cat 25, Cat 28, Cat 30, Cat 35, Cat 40, Cat R5. Inlets / Exhausts / Heat box Assy / DROP TUBES on Stock Shelf.
Forged New Bull Drive Gears for the Cat 30 from a 4 inch dia Bar 4 ft long HeHe. Tooled Up Dies to Forge to Shape. Its all about the GRAIN STURESURE inside the Metal when Forged. Compared to a simple Casting. LOL. Gear Cutting , Grinding and Heat Treatment etc.
All Good CM
1 year 1 week ago #250923
by Cat3600
Thanks for you reply. I did not see a private message or email response. No problem. I will double check what I need and let you know.
Thanks again.
11 months 3 weeks ago #251230
by Texasbest
Catman,
I messaged you also about an 8C heat box but I don't see where it was sent or not ?
11 months 4 days ago #251679
by Cat3600
Has anyone heard from CATMAN? I have sent PM's and emails and have not received a reply back. I was looking for CAT 30 heat boxes that he indicated they were making/had available.
Thanks,
Time to create page: 0.158 seconds
