Oil cooler
1 year 3 months ago #250222 by V14
Replied by V14 on topic Oil cooler
I am not that concerned since I knew I had some pressure just wanted to confirm it didn't need to be maxed out constantly like it was before. Just started it up again and verified it was fully over until it got warmed up and once the pony ran out of gas it dropped down to the midway point of ten and barely fluctuated and went up a little when I put it on more throttle. Unfortunately this thing wants to give me endless problems though since it bogged down and died when I tried to move it a little bit. Could be not enough throttle though I was in first at only about half throttle still learning what this machine wants from me.
1 year 3 months ago #250226 by aussiecat
Replied by aussiecat on topic Oil cooler
If my memory is correct sender units that operate a light on the dash turn the light off at 6psi. 10 psi at idle when warm would be ok.
The following user(s) said Thank You: V14
1 year 3 months ago #250333 by V14
Blade raising on its own again, im done dealing with it. Clearly i am not cut out for old cat machines, can't even move this thing 15 feet.
1 year 3 months ago #250337 by trainzkid88
Replied by trainzkid88 on topic Oil cooler
as your working it things are changing. it might take a couple of goes to get it back into proper adjustment. everything is freeing up with use ie the old hard grease aint dry and hard any more this might be allowing the bit of wear everywhere to affect the adjustment.
1 year 3 months ago #250348 by V14
Probably have to pull the cover off and actually clean all the plates. I'll get it, quitting smoking so my initial reaction was a bit over the top haha
Time to create page: 0.127 seconds
