D4 finds its way home
1 year 4 months ago #249654 by trainzkid88
Replied by trainzkid88 on topic D4 finds its way home
so its on the inside?
our machine had those done and they cut the mount off and welded it back on.
1 year 4 months ago #249659 by seyser
Replied by seyser on topic D4 finds its way home
I suspect the bolts that secure the bracket to track frame are quite a task to remove. I see someone tried to remove one on mine already as its broken off.
1 year 4 months ago #249691 by dpendzic
Replied by dpendzic on topic D4 finds its way home
I replaced the outer bushings in mine without removing the bracket
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
1 year 4 months ago #249696 by Deas Plant.
Replied by Deas Plant. on topic D4 finds its way home
Hi, dependzic.
Well, c'mon, Man. Don't just leave 'em hanging like that. Tell 'em how yer dunn it.
1 year 4 months ago #249698 by dpendzic
I removed the shaft as rome stated--the outer bushings were almost non-existent--so i collapsed them in with a center punch pulled them with a vice grip--the inner bushings weren't worn hardly at all being most of the forces are on the outer bushings---pressed the new bushings in with a threaded rod --froze the bushing and heated the bracket
the shafts were worn on the bottom rotation surface--so i built them up with steel fiber epoxy---so far so good but time will tell!!
The following user(s) said Thank You: Deas Plant.
1 year 4 months ago #249700 by seyser
The way I understand is there are 2 bolts and a retainer inside that are bolted onto the shaft which have to be removed before it slides out right? How did you remove those bolts without removing the inner bracket that’s bolted to the track frame?
1 year 4 months ago #249717 by dpendzic
now you have me scratching my head--it was over 5 years ago so i may have removed the inner racket? unfortunately the machine and parts books are over 200 miles away
1 year 4 months ago #249720 by side-seat
Replied by side-seat on topic D4 finds its way home
The two bolts he's talking about are threaded into blind holes on the lift shaft. Not the bracket on the inside of the track frame. Once removed or broken off , the whole triangular assembly pulls out. Of course the hydraulic cylinders and lift link needs removed.
