Dozer Chain
Dozer Chain
Thank you received: 90
1 year 6 months ago #248244
by kittyman1
why fight with track pins....when you can cut the link and re-weld ? be careful and always use masterlink when possible..
Thank you received: 7
1 year 6 months ago #248267
by gwoods
gwoods, kittyman1 I like your advice, being weak minded on where and how. Can you show me a sample. I don’t know where to cut and weld back together.
Gary Woods
Thank you received: 121
1 year 6 months ago #248271
by PhilC
I think he is joking. No one in their right mind would cut and weld a track link back together unless they were desperate and only needed it to last until proper repairs were done. My father did some dodgy repairs to get out of trouble sometimes but he never welded track links together.
1 year 6 months ago #248288
by kittyman1
not joking Phil or Gary....i did this 3 years ago on a D6c and it got me another 400 hours out of a totally shot chain(s)....
1 year 6 months ago #248289
by kittyman1
there is nothing special about a totally worn out, stretched chain....what do you have to lose?
1 year 6 months ago #248290
by kittyman1
you cut directly next to the center pillar, front side, top and bottom....make sure to stay away from the front bolt holes (shoe side)
1 year 6 months ago #248291
by kittyman1
use the thinnest cutting disc you can find....it makes a super clean cut like a knife
1 year 6 months ago #248292
by PhilC
Whatever works I guess. Not something I would do but anyway it worked for you.
1 year 6 months ago #248306
by kittyman1
yes Phil, not a proper fix or repair by any means, but it will buy a bit more time if funds are tight, or a machine that doesn't see much work etc..
- I did it because i didn't have any money at the time and the machine was new to me and I didn't know if what had was worth new chains....it gave me time to fix all the other issues, learn to operate dozer, and clear 20 acres of light bush....so for me...yes.
-sometimes you have to think outside the box, it's a much easier option than fighting with pins with no press...most people have a welder and angle grinder
-i learned this from my older Uncles who had dozers clearing land in Alberta and Sask many years ago, not a bad trick for poor Canadian prairie boys..
Thank you received: 34
1 year 6 months ago #248315
by Glum
Kittyman, I've done the same in the field on worn out chains to get a few hundred hours extra, and at times to get a job finished before machine comes home for major undercarriage work.
Usually to remove a link. Torch the front sction of one link and back of the other, fit the shoe to align bolt holes and weld up.
Dozer Chain
Time to create page: 0.184 seconds
