Cat 22 rescue
2 years 3 weeks ago #241882 by Kurt Bangert
Replied by Kurt Bangert on topic Cat 22 rescue
It has been a long time since I've had the 22, I don't recall. There is a parts book in the members section of this site, I'll see if I still have a service or operator manual.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
2 years 3 weeks ago #241883 by Kurt Bangert
I no longer have anything but the parts book, but as I thought there is an adjustment nut external, near the clutch pedal pivot. I definitely recommend getting manuals for the machine.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
2 years 3 weeks ago #241885 by daron
Replied by daron on topic Cat 22 rescue
2 years 3 weeks ago - 2 years 3 weeks ago #241887 by Peter C
Replied by Peter C on topic Cat 22 rescue
tkgeorge99,
If you are a member of ACMOC you would have access to the Technical Library Documents in which is posted the Cat 22 Operator's Instruction Book plus a whole bunch of other reference material to use as your collection grows!!!
As BruceOz mentioned the fuel pump may not be working properly. If you are going uphill with only a couple of gallons of fuel in the main tank, the carburetor may be higher than the fuel level in the tank starving the engine. A couple of my 22s don't even have the fuel pump installed.
I'm sure that this didn't happen to you but when I got my first Cat, a 22, I thought that first gear was left and down with the gear shift. Well, that's the way old floor shift vehicles were equipped. Showing my age here.
The main clutch is adjusted under the floor plate by the clutch pedal. The main clutch brake (to stop the clutch from spinning for gear changes) is adjusted through the flywheel clutch inspection cover on the top of the bell housing in front of the gear shift lever. If you have the tractor in gear with the engine running but the clutch pedal is pushed to the floor, so to speak, when the tractor is not moving then the clutch disc is not spinning. Putting it in neutral and back into any gear should be easy, that is no grinding. If there is grinding after being in neutral then the clutch disc and pressure plate/flywheel or pilot bearing is causing the disc to start turning when in neutral. Adjustment or cleaning of the main clutch may help. Adjustment of the clutch brake may be needed. If properly adjusted, the clutch brake stops the clutch disc from turning when the clutch pedal is pushed in to change gears.
Good luck with your 22. Neat tractor! Keep posting. We are a bunch of nuts who like pictures.
Pete
Last edit: 2 years 3 weeks ago by Peter C.
The following user(s) said Thank You: Kurt Bangert
2 years 3 weeks ago #241914 by tkgeorge99
Replied by tkgeorge99 on topic Cat 22 rescue
Thanks everyone for your replies, advice, and help. I have the original operators manual and parts catalog. Most of it is pretty good and has some pics but the paragraph on adjusting main clutch didn't have a reference pic to help out. And a few of other pics on some other adjustments aren't super clear. Voice of experience is sometimes the best.
Yes, my cat does not have a fuel pump. It looks like it was deleted when the hydraulic pump was added. It has almost 7 gal in tank so I don't think it was a fuel supply issue..... but intuitively when it bogs down, I feel like it must be a fuel or air issue. But, engine runs super smooth and rebuilt carb seems great. So I don't know.
I will adjust clutch pedal, main clutch, get tracks squared away, new plugs and wires, follow lube instructions in book, and change gear oil. I'm hoping by doing all these things, it will improve performance. My property is very hilly and I need machine to be able to climb up and down. Climbing the hill out, it felt super stable and had plenty of traction, only issue was dropping rpms and lost power.
2 years 3 weeks ago #241915 by tkgeorge99
I wish I coukd post video. I got some fun stuff of it crawling out of woods.
2 years 3 weeks ago #241923 by Rome K/G
Replied by Rome K/G on topic Cat 22 rescue
Check with Hahn for seat cushions, very good quality, 208-340-5084 or 208-841-0010
2 years 3 weeks ago #241925 by Kurt Bangert
You may want to check compressions as well
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
2 years 3 weeks ago #241926 by Peter C
Is this the picture that you need?
Pete
The following user(s) said Thank You: jbernd56
2 years 3 weeks ago #241927 by Kurt Bangert
This is what this club is all about - a big thank you to the OP, and a huge that you to all the contributors!
Great find on the 22, we're all looking forward to seeing it at work.
As far as video goes, YouTube or Vimeo would work.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
