Vintage Caterpillar tools
3 years 1 month ago - 3 years 1 month ago #231964 by edb
Replied by edb on topic Vintage Caterpillar tools
scans below may help.
With the grease valve shown below I believe that the text should read "4.5 psi to 5.5 psi" and not the "450 psi to 550 psi" or else the use of the low pressure relief valve would not be needed--from personal usage experience the pressure relief feels like 4.5 psi to 5.5 psi on the handle as the lube comes out the RV with little very handle down pressure. In fact sometimes one wonders if any grease/oil went in at all.
Last edit: 3 years 1 month ago by edb.
3 years 1 month ago #231967 by PhilC
Replied by PhilC on topic Vintage Caterpillar tools
Hello All
Does anyone know what this dial indicator set is used for?
Regards
Phil
3 years 1 month ago #231973 by Rome K/G
Replied by Rome K/G on topic Vintage Caterpillar tools
Setting the rack on injection pumps.
3 years 1 month ago #231991 by edb
Hi PhilC,
is there a group part number on the box?
I feel I have used this group way back for dynamic rack readings--which engine I do not recall but by the two bolts and shape of the rod end of the bar it may be D300 series engines--Cat came out with many variations of tooling in this era for the same engines but in different applications--the different tooling and application accessibility often dictated which one was used, and some tooling was easier to use as designs changed.
3 years 1 month ago #231992 by PhilC
Hello Eddie
The numbers in the auction are 9S215 Dial Indicator & 9S7350 Bracket.
If its for the D300 series engines I might have to add it to my collection:)
Regards
Phil
3 years 1 month ago #231993 by rax200
Replied by rax200 on topic Vintage Caterpillar tools
Hi Eddy and PhilC,
This link will show you which engines
www.catengine.info/workshop/3306/d330-d3...-diesel-engines.html
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
3 years 1 month ago #232002 by edb
Hi rax200,
alas my web blocker says that is a malicious site so I cannot get to it.
Thanks,
3 years 1 month ago #232003 by rax200
Hi All,
I have a couple of more tools to add to the list,
9B2089 early injector socket to remove and install.
3B6780 socket to remove the special nut on the layshaft on D4's
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
The following user(s) said Thank You: Deebo
3 years 1 month ago #232146 by Deebo
Replied by Deebo on topic Vintage Caterpillar tools
Just ordered a NOS 3B6780 from Florin, thanks for the pic, now I know what to expect!
The following user(s) said Thank You: rax200, Fat Dan
3 years 1 month ago #232273 by rax200
Hi All,
here is another too that I picked up a few months ago, it is for removing precoms chambers from press in type heads,
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
Time to create page: 0.473 seconds
