- Thank you received: 185
Hello Neil, I got some more serial numbers from the carcasses littered around the property here in Richmond (Ralph Ching) I mentioned earlier in the thread. One could even be your Father's old 5U!Ok found the Goughs serial # listing:
- 5J3036 - R. Raine, Stoke
- 5U519 - F.S. Nola and Sons, Ltd. - Auckland (Kumeu)
- 5U5576 - B. Linnell, Kaiwaka
- 5U6373 - J.R. Byers, Gore
- 5U13058 - I.K. Campbell, Heriot
- 5U15604 - C.A.E. Cashmore and Sons, Ltd., Auckland
- 5U18507 - W.R. McNabb, Nelson
The one from Auckland migrated a fair distance. Let me know the serial # of your cousin's Twenty-Two and I'll look it up. I counted up the # of units that were listed specifically in Marlborough and it's a pretty decent # - 5 Two Tons, 26 Tens, 18 Fifteens, 12 2F Twenty-Twos, 14 1J Twenty-Twos, 3 4J R2s, 6 6J R2s, 5 3J D2s, 21 5J D2s, 64 5U D2s, and so it goes. At the time these listings were printed out, there were 406 Twenty-Twos imported, and 1838 D2s/R2s. Seems like a lot for a fairly small place where the import price was high.
I got this listing from John Neal who hails (hailed?) from Budge St, Blenheim I think about 20 years ago__PRESENT
Yes, we knew it was a very likely runner when we went out there as it was running when it was parked in the shed 10 years ago, but the pony developed issues (no spark, which I sorted on Saturday) and he couldn't get it started again. My friends are going back there to get it running and picked up, the main interest I had in it was looking at it for a friend, as I have recently purchased my own: www.acmoc.org/bb/discussion-d72/27964-fo...-3940-original-hoursYour half way to getting it move if the pony ran and the main turning. Figure out temporary tank to get it home. Good luck to you. Very nice looking machine.
Thanks again Neil, we took the hood and air cleaner off it so we could get at the pony motor as it had issues with the mag, (which I managed to sort). The starter motor would have been long gone unfortunately as there is not battery box nor any other electrics. The main reason I wanted to look at it is for my friend, who is very interested in purchasing a D2 dozer, unfortunately, I don't think this is a good candidate for him, the tracks are absolutely worn out (to the point of cracks in the rails) the track frames have been patched/hacked around, and the idlers have been built up. Not only that, the brake pedals are almost smooth and all the levers have tons of slop in them. All in all a very high-hour machine.5U14756 - some other info. Anything newer than 5U13273 has the two-piece clutch shaft / longer track frames enabling the main clutch to be changed without having to split the tractor. Saves a bucket load of time when doing that job.
Have a look around to see if you can find the starter motor. I see that the main engine air cleaner is on the ground behind the tractor. Make sure that goes with it. Really should reinstall it to keep critters out. If you have occasion to clean the oil bath cleaners, do not steam clean the mesh. Instead use solvent to ease the dirt out. Edb has posted a procedure here whereby one stands the air cleaner body on a pedestal in a drum with kero or diesel or any kind of cleaning solvent like those, and use compressed air to bubble up through the mesh. The bubbles cause solvent agitation inside the mesh and dislodges the dirt, which can fall to the bottom of the drum, beneath the compressed air emitter. If that's too much, you could put it in a big ultrasound cleaner again with an oil-based solvent.
cat@acmoc.org
- Chris R
- Jason N
