new grader help wit hid and info
16 years 6 months ago #17066
by handhewn
About the stuck pony motor, I had a six cylinder engine in a "White Super Power". I tried for two years, using anything and everything I could find to get it unstuck. I talked to an old man I new to be a good mechanic and he laughed at me and said,"just pour a can of pepsi in it and turn it over tomorrow". To my complete surprise it worked. He did say that it was important to get the pepsi out as soon as possible as it would cause damage. I asked another friend of mine who is a doctor of chemistry about all this. He said the Pepsi would work great and that it would not cause problems if left in place. All I can say for certain is that I was able too turn the engine over one day after pouring the Pepsi in. I'm still driving that truck twenty years later.
Floyd
16 years 6 months ago #17077
by Soapy
Floyd
Read the side of the can that shows what it contains. The one that cuts the rust is Phosphoric Acid
16 years 6 months ago #17085
by SJ
Tell your wives that if the dishwasher gets that scum buildup inside it an easy way to remove it is get a container of the dry Tang orange drink mix and without dishes in it fill the soap container with it like you would the soap powder and run it through a complete cycle and it will remove it to a shiny new look.
16 years 5 months ago #17598
by moonshadows
thanks to everyones help i've gotten my grader running--- i still have not gotten the pony to start i got it turning and spark but still no fire i think the valve are still hanging up as they where crusty but ill get it !! but a quick jerk wit ha chain and it fires right up {should see my 90 pound wife standing on clutch pedal on my 504 international pull starting me on the grader} but once it fires it runs ok and now that the pony is mounted i can run it for a little while ill bleed out he injectors and i am sure it will run much better ---scott
16 years 5 months ago #17617
by moonshadows
any idea why i cant seem to find 1st gear ??? i know where it should be but it does not seem to be there itll slide all the way over to the right but then doesnt feel like there is any groove notch for it to go into so it can engage a gear {does that make sence??}
Time to create page: 0.161 seconds
