new grader help wit hid and info
16 years 6 months ago #16852
by moonshadows
well iam finally going to get my "new" grader tomorrow my dad found it on craigslist for me and bought it two weeks ago and i finally had time to go get it. today was the first time i got to see it in person the only number i could find was a tag that had the number 1U-166 stamped into it. i need ot know what model this grader is so i can start researching for parts and manuals so i can get it going. the thing is in fair shape looks bad but not too bad really tell me what you know about it any info or advise ---scott
Thank you received: 820
Thank you received: 405
16 years 6 months ago #16864
by D4Jim
Scott, have you been around old Cat graders before? There are a zillion grease zerks on the critters and several places one has to check for fluids in gear boxes etc. A good set of manuals is definitely in order.
Does it run? Looks like a pretty decent machine with scarifier and all. Keep us posted on the progress!!
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
16 years 6 months ago #16891
by moonshadows
i dont know anything about graders it is supposed to run or it did in the past when pull started. the pony is stuck iam going to look into getting it going also have been reading and looking into the electric start conversions listed on this site thanks for the info on the vintage and model that will help in getting manual i like old junk like this and dont mind tinkering and making obsolete parts i also have a 35 mccormick deering td-40 w/ b/e blade setup on it and a bunch of little bit newer junk too but i really like the older stuff more ---scott
p.s. this is not going to be a show piece it has work to do when i get it going i use my old junk
16 years 6 months ago #16892
by moonshadows
also it has new 8.25 20 tires on the front but the rears are mis matched junk even has one 24.5 on one of the rims what size is supposed to be on the rear ??? i was guessing 1100x24 but would like to find out before searching ---scott
16 years 6 months ago #16906
by D4Jim
I believe the 212 came out with 10-24 tires. If you get a wider tire, it will be larger diameter and it may not fit as the 212 has limited space.
www.denmantire.com/catalog/8.pdf
13-24 is the most common grader tire but it is to large for the 212.
You might send an email to ccjersey as I believe he has a 212.
D47U 1950 #10164
Thank you received: 10
16 years 6 months ago #16908
by ccjersey
That's right, the machine came with 7.00x20's front and 10.00x24's rear. Later machines after 9T4762 had 21's on the front, but there were optional rims to convert that back to 20's and also wheels to take the 10.00x24's on the front.
16 years 6 months ago #16914
by moonshadows
that is good info it has two 1100 24's one i think might be a 1000 24 and one 1100 24.5 ??? the two 8.25 20 on the front are new and i thought they looked a little big/wide for the rims but they will be ok for now i guess --- the pony is stuck so i will probably get some oil into the cylinders today see if i can free it up and start making parts to do that electric conversion like i saw on here i was told this unit ran recently by pull starting it so hopefully ill get it all going ---scott
16 years 6 months ago #16921
by ccjersey
Potential killer problems include
breaking the vertical shaft coming into the bottom of the control gear box (later machines had a shear pin in this shaft) so make sure you don't drive one of the controls into the end of it's travel. It will train you not to do this by smacking your palm as it jumps out of engagement. Best to wear gloves and make sure your control levers have grips on. You want to quickly engage and then completely disengage the controls, not attempt to "ease it in" like it was a clutch. It is a gear dog type engagement that meshes up when you push or pull the lever.
Steering box is expensive and getting rare. There are some substitutions from larger/later graders that can be done. It's worth rebuilding or adjusting the slack out of the worm bearings as needed to keep it from shattering the worm when the rack climbs out on the end of the worm thread and jams. CAT quoted $1200 for a new worm when we asked.
Looking at your pictures, I doubt you will be bothered by water in things, but you might want to drain a bit of oil out of the two blade lift boxes on the front of the main control box just to make sure there's not water in the bottom of those boxes. We had one with and one without water.
I have been amazed what ours will do on so little hp. Hope you find everything is in good shape.
It won't be a whole lot of trouble to take the pony motor heads off to clean the cylinders inside. You can usually reuse the gaskets, or they aren't too expensive anyway. Tighten head nuts evenly to 32 foot pounds when you go back.
Plug wires should be WIRE core, not carbon core and most common recommendation is NGK AB6 plugs.
If you have to go into the magneto, pay attention to how the rotor is timed to the gear behind before you remove it. You probably will have to file the points and regap them to 0.014-0.018 inch gap.
Almost certainly have to remove and clean the carburetor bowl, lines and tank. It is a great idea to add a filter inline once you get your carburetor clean so it will stay clean. there seems to always be some more rust somewhere even if you reline the fuel tank with one of the splashing compounds that are available. Then if you cut off the starting motor by running the carburetor dry each time, you will have very little trouble with fuel varnishing up on you or deteriorating your float.
Good luck!
Have Fun!
16 years 6 months ago #16935
by moonshadows
what is the sequence of the serial numbers ?? this one is 1U-166 found a book for 9t1 and up is that newer or older "1" would be first or is the letter the important part then t would be first ??? let me know thanks ---scott
