Front PTO shaft D2
Front PTO shaft D2
16 years 7 months ago #16096
by smf52
I dont have any pics of the unit on the dozer but I will take some when i mount it back on.
Thank you received: 32
16 years 7 months ago #16101
by Jack
I don't recall having but two bolt holes in my pulley--puller bolt holes--which I used. Were the other four tapped for the adaptor or do some of the pulleys have six holes?
That's a pretty good looking setup, but it wouldn't have worked too good on mine. The radiator shell got sprung against a stump or something before I ever got it.
Thank you received: 47
16 years 7 months ago #16103
by 8C 361
I have a 5J parts engine and I think it has 4 bolt holes...might be wrong.
That adapter looks like one I had that came off a RD4. I wonder if it would fit if I could ever find it. It did have the setup for the square shaft. I didn't think that looked like a very good setup but I guess it is. It would be real easy to adapt to pump. It looks like they just cut a square shaft the right legnth and welded it to a coupling that fits the pump or rather the flex coupling. I think I would use a lovejoy coupling.
It is hard to tell just what my 5J that I want to put a pump on has on the pulley with the radiator on there.
I do have a 5J converted T2 loader that has a vickers vane pump on the front driven by the chain type coupler. I would take pictures of the setup but it is hard to see anything without dismantaling it.
Those are excellent pictures smf52, thanks a lot.
Has anyone contacted that outfit that SJ recommended to see if they have that animal available?
Tom
16 years 7 months ago #16104
by drujinin
The aluminum spacer goes between the pump and the radiator shell? Its interesting that the shell is stiff enough to support the weight.
My 5J has a locking ring around the crank stub with 4 bolts in it which would make the total 6.
Thanks Again!
Front PTO shaft D2
