Front PTO shaft D2
Front PTO shaft D2
Showing 1 to 10 of 15 results
2bluejon
Send a private message to 2bluejon
Hi i am looking for a part that i can put on the crank so that i can mount a hyd pump on the front of the crank on a D2 5U9377. I have heard that it bolts on to the pully can any one help me on where i can find the shaft or where i can get one thanks Vern
Sat, Apr 12, 2008 10:43 AM
SJ
Send a private message to SJ
Vern, a short time ago I picked up a place that handles Cat used parts so give him a call. It is Edgecomb and they are in Illinois and his # is (815) 220-7715 & E-mail is [email protected]
Sat, Apr 12, 2008 10:27 PM
Reply to SJ:
a picture of that part! and possibly the mounting arraingement. I am working on the same project for my D2-5J while its all tore down.
Sun, Apr 13, 2008 8:24 PM
2bluejon
Reply to drujinin:
i do not have a pic i do not know what it looks like i need help to thanks Vern
Mon, Apr 14, 2008 8:57 AM
Jack
Reply to 2bluejon:
The 5J wasn't built for a front pump drive like the 5U was. The front pulleys are a lot different. There's a stock connection for the 5U. I've never seen one for the 5J, and the 5J has no attachment flange on the front for the pump mount. Unlucky for us with 5J's, but not unsurmountable.
Mon, Apr 14, 2008 10:56 AM
Reply to Jack:
the radiator Saturday and wondered how to mount it as the material looks thin. I see in my mind something coming from underneath the casting for the radiator, going up in front of it and not attaching to the radiator housing at all.
Or building a stout shaft mount for a belt pulley to hook up like the 1938 D2-3J on Ebay has.
It is only supposed to lift the blade. Wouldn't a belt drive do that?
Tue, Apr 15, 2008 2:23 AM
2bluejon
Reply to drujinin:
Does any one have any pic of a PTO shaft that they have home built i can not pic what i need to do thanks Vern
Tue, Apr 15, 2008 8:54 AM
Reply to 2bluejon:
I have a 5J with a #44 hydraulic control on it. I'll have to see what the arrangement is.
Now that I think of it, it has the wrong radiator on it so that may be why.......they wanted to mount the #44 so they swapped the radiator for a U series to make it easier.
(comprehension dawns slowly)πŸ˜‰ So that's why that happened, duh!
http://www.acmoc.org/ACMOC_BB/attachment.php?attachmentid=1161&d=1173237419
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare timeπŸ˜„
Tue, Apr 15, 2008 9:54 AM
smf52
Send a private message to smf52
I have a 5J with a professionally build front PTO adapter. It fits inside the front pulley over the manual crank teeth and uses 6 bolts to attach. It has a female square hole that adapts to a 3/4" keyed shaft to run a pump. It also has a aluminum spacer that mounts on the 5j rad using the 2 hand crank cover bolt holes. The spacer is set up for a SAE flanged pump. I will get pics when it gets light.
Wed, Apr 16, 2008 7:32 AM
2bluejon
Reply to smf52:
thanks every one has been great to help mw with this
Wed, Apr 16, 2008 10:02 AM
Reply to 2bluejon:
all the photo's of that arraingement if you would post them as large as possible!
Wed, Apr 16, 2008 5:40 PM
