- Thank you received: 6
Split rims are not the same as multi piece wheels. Please consult the OSHA regs, sometimes they are here to help. It is a sticky.
Well said. A rim with the retainer ring is a totally different animal than the old split rims which split near the middle of the rims. They split rims which have been banned for years had a connecting ring about two inches wide with both edges curled over to catch the wheel halves. You have to look pretty far to even see one any more. For years most folks have mistakingly called a retainer ring wheel a split ring.
Nothing wrong with a retainer ring wheel. Most heavy equipment tires still use a variant of them.
And that's why they're such a problem to get worked on.... folks don't understand the different types and just lump everything that's not a drop center into "omg it's going to explode and kill everyone in 500 yards"
Here too there's that magic liability word which translates to no shop is going to anything that has any chance at all of being the grounds of a lawsuit no matter how asinine.
I have been frustrated by our U. S. based heebie-jeebies about any multi-piece wheel. Those old "true" split rims, like old-iron-habit mentions, really were dangerous if worked on by an untrained person. They could also be dangerous in a flat or low pressure situation. Our OSHA type people have done such a disservice to all of us by perpetrating the "safety culture" around those to the point that the fear created bears no relationship to the facts. I've found that most modern tire shop people these days, most of whom have never in their life seen a true split rim, run screaming away if you drive up with any multi-piece wheel.
It is really sad as mrsmackpaul and others are correct, there are big advantages to the multi-piece design in certain applications and, in fact, they are still used on many large off-road tire applications here.
The one thing I have found, as a guy who typically runs rag tires and tries to get the last ounce of tread wear out of my tires, is that for road use, where multi-piece usually means tube type, the lower heat generation component of tubeless tires usually means much better reliability. It just seems whenever I'm running our trailers with two piece rims and tube type tires, I end up handling that spare for some reason or another pretty regularly. On the other hand, when I'm running our trailers with tube type tires, I just never seem to use the spare.
For road use, particularly for trailers, tubeless (usually meaning drop center) just usually equates to no trouble as long as you check your tires regularly and don't run a low tire. Tube type tires turn me into a nervous nelly, checking each tire each time we stop and still result in me getting some exercise running the jack, undoing lug nuts and swapping in the spare on many trips.
That experience is enough to interest me in switching to one piece, drop center wheels and radial tubeless tires on our stuff, when I can afford it.
Pete.
support@acmoc.org
- Chris R
- Jason N
