Pony motor
5 years 6 months ago #200991 by EastonTexas
Pony motor was created by EastonTexas
Anyone have these parts for engaging the pony motor?
5 years 6 months ago #200994 by d2gary
Replied by d2gary on topic Pony motor
With what you can salvage from yours I probably have most of the pieces to rebuild yours
5 years 6 months ago #201014 by oldbeek
Replied by oldbeek on topic Pony motor
I have a complete pinion assy off of an 8t cat 12 grader. D315 engine. I working order. $300. + shipping.
5 years 6 months ago #201020 by mog5858
Replied by mog5858 on topic Pony motor
the 8T would be a D318 not a D315? might be the same i not sure
5 years 6 months ago #201024 by oldbeek
You are right. Don't have a complete assy # but housing # is3b6402 and pinion is 6b1360 13 tooth. It was also the same assy as off a 9k with the 466 eng 6cyl. My question is if it looks that bad, what does the pony gear housing look like. I would pull it down further to see what the rest looks like. The pony has to be lifted to extract the pinion assy.
5 years 6 months ago #201044 by EastonTexas
Replied by EastonTexas on topic Pony motor
I was trying to make sure everything is good on engaging and disengaging. It's on a d4 5t dozer. I still need a magneto but I hooked power to the starter and the pony motor does turn along with the engine. I have the lever off but its engaged to turn the engine
5 years 6 months ago #201046 by oldbeek
Is there a way to reach the latches on the pinion to disengage it? I probably have a mag. It may have the wrong orientation for the impulse coupler, but if you have electric starter on the pony the impulse is not needed.
5 years 6 months ago #201051 by STEPHEN
Replied by STEPHEN on topic Pony motor
The D4 mag does not use an impulse coupling. The A/B mag that looks close, but has an impulse instead of a gear may be from a D318 pony.
5 years 6 months ago #201052 by EastonTexas
How hard is it to slide the housing off? The bolts were out of it but the housing wasn't free. I don't know much trying to learn and fix it at the same time. I wanted to see what parts were available because I didn't know how easily I could get parts. They look pretty bad but I wanted to see if they'd clean up enough to function ok
5 years 6 months ago #201055 by gemdozer
Replied by gemdozer on topic d4
You need to lift the starting engine 2 to 3 inchs for pulling out the cluch housing and need too draine the coolant from the big motor before lift starting engine and if you can angaged the the lever pinion it could help too.
Time to create page: 0.193 seconds
