FOR SALE/WANTED
d6 engine lifting eyes
8 years 8 months ago #141268
by monserandsons
im looking for a pair of lifting eyes for a d318 like pictured in the servicemens referance book. including the nuts with spacers. i would have had my engine out today but couldnt decide on appropriate lifting arrangement
Thank you received: 344
8 years 8 months ago #141279
by edb
scan below may help. This is what we used at the Dealer for all D315/D318 engine applications--plus anything else it may fit safely.
8 years 8 months ago #141337
by monserandsons
can i put this directly to the covers and then just snug the plate down to the covers or do i have to remove the covers and have a nut above and below the channel? thanks again for your time
8 years 7 months ago #141345
by edb
Hi,
we used to remove the nuts and the sealing aluminium washers and fit the bracket on the studs without removing the covers. The studs were long enough to do this in my experience, we usually used flat washers over the slotted holes in the bracket for safety.
Thank you received: 77
8 years 7 months ago #141386
by dpendzic
any idea on the weight of a D318 engine?
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
8 years 7 months ago #141407
by edb
Hi Dan,
by two different spec. sheets here I see around 3100lbs dry weight for a basic engine, do not know what if any attachments may be on it to be more accurate for you.
Someone else may have more definite figures.
8 years 7 months ago #141409
by dpendzic
Thanks Eddie---that will give me a ballpark number to check the rigging I need!
8 years 7 months ago #141410
by STEPHEN
I like the channel style beam, will have to make one. Here is a bit of rigging I made to lift a D8800. Used trailer D rings and some heavy angle.
Thank you received: 45
8 years 7 months ago #141420
by ag-mike
does this work with the radiator attached?
FOR SALE/WANTED
Time to create page: 0.171 seconds
