D4 final drive leaks oil
17 years 4 months ago #7240
by tinytec
OM, Thanks for the quick reply and your expertise. I'll have to digest this one for a while.
Glad to hear at least the sprocket teeth are OK.
Fred
17 years 4 months ago #7307
by Oz22
Tinytec,
Just another thing to check, look at the nut for the pivot axle under the machine where the undercarrige attaches and check to see if the pivot axle is loose, could be that the bearing adjuster has just run out of thread because the axle is moving out. Not something many people check and could save some time and dollars if its just loose, but if it has been loose for such a long time the damage could be extensive. Worth a look though because these things usually show up after being stuck as you were.
17 years 4 months ago #7313
by tinytec
Oz22,
" look at nut for the pivot axle under the machine where the undercarrige attaches and check to see if the pivot axle is loose, could be that the bearing adjuster has just run out of thread because the axle is moving out"
I don't recall seeing a nut underneath the machine that would affect the axle position. The female thread of the adjusting nut appears to be totally stripped, even when it's over the mating male threads of the bearing cage.
Thank you!
Fred
Time to create page: 0.147 seconds
