D4 shifting - gears clash
17 years 5 months ago #6441 by tinytec
In a previous thread (D-4 buried) I successfully adjusted the D46U-2831 vintage flywheel clutch from the top side. Now, after the initial engine start, it's impossible to shift the tranny without gear clashing. The only way to get it in any gear is to slow the engine down to almost stalling and go for the highest gear. Once it's in a gear then you can shift into any other gear as long as the flywheel clutch is not engaged.
While dozing, if the CAT is brought to a complete stop you can shift to other gears with no clashing as long as the clutch is not engaged while the tranny is in neutral.
I tried to adjust a clevis link that looks like it is supposed to stop the flywheel drive shaft from free-wheeling while in neutral. The adjustment is screwed out as far as possible without the screw falling out of the clevis but there is still almost a 1/4" gap between the discs of what appears to be a small friction brake.
Is there an easy solution to this new problem? Can I weld an extension to the clevis bolt so the friction discs contact each other?
Fred (tinytec)
17 years 5 months ago #6443 by Old Magnet
You need to push the clutch lever forward to engage the brake. Are you doing that?What clevis are you referring too? If it's the one on the release lever above the deck that doesn't do anything but change the lever position. You shouldn't have to mess with the rod/clevis down in the clutch compartment.
17 years 5 months ago #6445 by edb
Replied by edb on topic Clutch Brake
Hi again tinytec,
as OM has said above, provided you push the clutch control lever forward it should engage the clutch brake. There is no adjutment procedure or length of linkages given in Serv. Lit. that I am aware of for the clutch or brake linkages.
I would suspect that a stack up of lost motion due to worn :- shafts, bushings, linkages, and thrust collar and flange is the most likely problem, I guess your clutch lever is hitting the floor plate or the firewall. There is a double sliding spring setup on the detent linkage to allow this linkage to adapt to various linkage lengths when the clutch is adjusted to take up any wear.
I guess, as a tempory fix, you have nothing to lose by lengthening the rod and seeing what happens, provided nothing else in the clutch linkage/compartment clashes, and the clutch continues to be engageable.
Hope this helps,cheers,
17 years 5 months ago #6449 by tinytec
Replied by tinytec on topic D4 shifting - gears clash
OM: Yes, I push the clutch lever fully forward. The rod/clevis I'm referring to is on the left side in the clutch compartment.
Eddie: There is a lot of accumulated wear in the linkages. As you suspect, the clutch lever hits the floor plate in its full-forward position.
Another thought just came to mind: Is it possible the drive shaft sleeve coupler has slipped forward on the (splined?) shafts so it is now farther away from the friction brake disc? The coupler looks like a two-piece split coupler with bolts and locked nuts.
BTW, the clashing problem didn't exist before I adjusted the clutch.
Thanks again for your information.
tinytec (unstuck Fred)
17 years 5 months ago #6452 by ol Grump
Replied by ol Grump on topic D4 shifting - gears clash
I had a D25J that I bought that did the same thing when it was cold but when warm, most of the prob went away and shifting, while not exactly the way it should have been, was possible. After dumping some diesel in the clutch housing, then engaging and disengaging it for a few minutes while warm and running and then draining it fixed it.
About the only other suggestions I have is to tear into it, either replace badly worn parts or braze, redrill and ream 'em. Don't forget to replace the brass bushing in the top of the clutch housing with a new one, that's where a lot of slop usually is.
17 years 5 months ago #6458 by Old Magnet
On occasion the coupling has been known to shift. It is held in place on the shaft by a couple of circular rings but have been know to wear into the coupling or sometimes get left out. You can try fiddling with the clutch yoke adjusting clevis but you may have to readjust the main clutch in the process. Seems like your dealing with worn parts and that last adjustment used up the range.
17 years 5 months ago #6459 by 8C 361
Replied by 8C 361 on topic D4 shifting - gears clash
After fiddling with these clutches for 40 years or so it has come to light that one of the biggest culprets in the performance of these clutches is the 7B5758 cams. When I was adjusting the D8 clutch everything was larger and more accessable to view and is exactly identical to the D4. It seems to me that the profile where the cam contacts the pressure plate must wear over time. This cam is what provides the snap that put pressure on the plate and also provides for the amount of release avaliable. I wonder if these cams are still available from Cat and what the cost would be. On the other hand it seems to me it would be possible to remove them and build them up with hardface rod and re profile them.
17 years 5 months ago #6463 by Old Magnet
It's not just the cams....but a combination of wear on the links, pins, and cams that makes up the toggle mechanism or the lack of.
17 years 5 months ago #6467 by tinytec
Eddie ("There is a double sliding spring setup on the detent linkage to allow this linkage to adapt to various linkage lengths when the clutch is adjusted to take up any wear.")
Your info. makes me wonder if this double sliding spring linkage has a problem. I will get back to the CAT on Tuesday, and with the help of all inofrmation given here, will look into the linkage more thoroughly.
Thanks again . . .
tinytec Fred
17 years 5 months ago #6563 by tinytec
Reference from previous posts:
Eddie: ("There is a double sliding spring setup on the detent linkage to allow this linkage to adapt to various linkage lengths when the clutch is adjusted to take up any wear.")
tinytec: Your info. makes me wonder if this double sliding spring linkage has a problem. I will get back to the CAT on Tuesday, and with the help of all information given here, will look into the linkage more thoroughly.
I worked on the clutch linkage today and noticed there appears to be only one spring, not two, near the clevis.
I caused the gear clashing because I previously adjusted the clevis in the wrong direction. I had extended the clevis as far as possible without the threaded portion falling out of the clevis assembly. Today I reduced the clevis length - this eliminated the gear clashing by allowing the brake disc to stop the free-wheeling transmission shaft while shifting gears. When I mis-adjusted the clevis it prevented the brake friction surfaces from ever making contact with each other.
Now I'm wondering if there is a missing spring in the double sliding spring linkage. . .
tinytec
