R2 3400 engine
17 years 6 months ago #5921 by catrat
R2 3400 engine was created by catrat
Hi all Old Magnet=SJ have a question on the clutch i put in my R2. I can't get adjustment to where it clicks over center.:confused: It is not runing yet have been playing with this clutch don't want to put on the gas tank and base till i am sure clutch works right. It acts like the new clutch disk is to thick linkeage won't move at all if i adjust it in. Turning to the right clock wise. Am i doing some thing wrong.
catrat:mad:
17 years 6 months ago #5922 by ccjersey
Replied by ccjersey on topic R2 3400 engine
the clutch (or the engine) should be free to turn before you start adjusting the clutch adjuster up. At that point move the lever to engage the clutch and watch it to see how it all moves. If all is well, begin adjusting and snapping the clutch in each time.
At some point it will start to snap over center, very easy. If you tighten farther, it will get harder and eventually won't be able to snap over center.
If your clutch linkage is too worn, you may not have enough travel to make it snap in before the clutch lever or linkage hits something.
17 years 6 months ago #5924 by SJ
Replied by SJ on topic Clutch
I,m only guessing but maybe it,s too tight to begin with so back it off CCW & then start going clock wise a little at a time & keep trying the lever to see if it snaps in & see what happens. Also CC gave you some good advice so check these things out.Let us know how you make out.
17 years 6 months ago #5941 by catrat
Replied by catrat on topic R2 Clutch
Thanks CC + SJ will try what you sugested. The engine turns over good. Linkeage is in good condition very little loose ness or slop in it. When i back the linkeage off i get some movement from the clutch stick. If it is up near the disk no movement. Totaly lost Don;t want to pull engine back out i work by my self and it ain't easy:)
catrat
17 years 6 months ago #5943 by edb
Replied by edb on topic clutch adj.
Hi catrat,
as SJ suggested and you have described, I too believe your clutch is adjusted too tight. Keep backing it off, if you can ?, until you get the snap as described in the attached D2 3J-5J OMI. I believe the R2 clutch to be the same.
My experience of these type clutches is that the adjustment takes up quickly and very little movement is required (a hole or two either side of the best position) to go from loose to won't snap over, as you are encountering.
Chin up, Cheers,
PS "man will triumph over metal".
17 years 6 months ago #5979 by catrat
Thanks CC+ SJ+edb i removed the engine again today and found that i had a set of dogs not alined right on the rear clutch plate. When this is in place and clutch is adjusted should i be able to release the clutch. Then re tighted to get it in line for engine instalation. This is a real pain for what looks so simple.
17 years 6 months ago #5980 by Old Magnet
Replied by Old Magnet on topic R2 3400 engine
Couple of things:
Would seem like you have some well worn parts....links and pins to get the dogs (cams) out of position.
No problem releasing the clutch for installation but I'd save the tightening and adjustment for when it is installed in tractor.
17 years 6 months ago #6091 by catrat
Thanks CC- SJ- edb- Old magnet. All the parts and linkage is in good condition redriled parts new pins. The biggest problem i think was the 1 year between disassembly and reinstall :confused: {CRS} have it back togather now and appears to work OK:) Will get the other items on this week and see how it runs and maybe operates. It has been a long battle not used to this outside work space. Just moved [last year] from a 60+60 shop to a 16+20 just enough room to stor e a few tractors and tools.
The main problem was i missed the set ov dogs at the transmission were not lined up. I thik they may drive the pump when clutch is inguaged.
Again thanks to all I knew you would have answers
[;) If it can't be found here may as well scrap it]
catrat
17 years 5 months ago #6589 by catrat
CC-SJ-edb-Old Magnet have the R2 running now but pooor. The problem i am haveing now is it is back fireing through the carb. I did NOT touch the timeing when this engine was apart. I am thinking that the valve timeing due to valve adjustment may be the problem
. The rockers are wore some so i have located an other set appear to be real tight. The back fire it not real bad just enough to here a cough now and then. This engine ran good before it ate that valve head. Real pain to pull the cross over hyd. lines and get the valve cover off. All and any help needed
catrat
17 years 5 months ago #6590 by Old Magnet
What have you got the valve adjustment set at?? Don't know what all you replaced, did you redo valve guides, replace springs??. Has all the symptoms of weak valve springs. Jam a big screwdriver between the valve spring coils while it's running. If that's it the back fire/cough will stop on that particular cylinder. Are you getting a nice fat spark from the mag and does the carb respond to adjustments?
Time to create page: 0.182 seconds
