- Thank you received: 0
Only fog round here is when the daily heat strokes kick in & my world gets shaky & foggy....face gets red, mouth dry.....pub time!:cool:Hi ttman4,
Enterprising in that someone realized they would get filtering of circulated fuel instead of just looping the suction line.
None of the "U" series had dedicated tank return lines. At least not from the factory;)
With a little imagination I guess you could consider the supply line to be both as there was no check valve to prevent back flow.
Ya need a trip to the coast to cool off.....typical fog in the am burning off at about 11:00 temps in the 70's:D
Yeah, I put a 1/2" ball valve reduced down to 3/8"on each end of loop. I could restrict at top coming out of ther. housing.I suppose you could put some kind of restrictor in your heating/cooling loop to slow down the flow. That circuit was used for engine heater and flow/temp sensing on stationary engines where free flow was preferred.
support@acmoc.org
- Chris R
- Jason N
