- Thank you received: 818
OM, "enterprising" meaning they figured out an easy change? Or they just figured out that if it comes on later models that have valve mted. on top rear, then it's a better filtration set-up?The "U" series tractors with factory direct electric start and hand primer pumps have the relief valve mounted at the top (rear) side of the filter housing with the return line tied into the supply line. Some enterprising folks have realized that having the valve in this location provides filtration to the recirculated fuel unlike the one mounted on the inlet that allows recirculation of unfiltered crud through the transfer pump.
support@acmoc.org
- Chris R
- Jason N
