- Thank you received: 0
So here is my question;
I want to put a hyd. pump on and drive it from the generator drive gear, it will be a 15 gal. pump at 1500 psi. this is adaquate for the pressdrills. On this set up the pump has a through shaft that I would like to drive an alternater also. What do you think, will the timing gears on the D2 handle this load?
Do you know of any that have done this, and/or what are your thoughts on this. These pumps come off the TD61s and TD91s and ran off the timing gears on these tractors without problems
John
support@acmoc.org
- Chris R
- Jason N
