- Thank you received: 321
98j try to fit a trip to California the last weekend in June into your schedule(know how that is when farming you have to do what needs doing)to show Tom Madden has a sticky for on this board.A neighbor has been working on his old cat34 combine I think it is.Has gone all out has all new canvas for the header.Looking at the sticky sounds like there will be others as well.As always great pictures ,thanks for sharing.
As for the third wheel I was under the impression they were standard on all pull machines by all makers,as none of wheel tractors of era where able to handle the tongue weigh of pulling one of these as a level land machine.Around here they all went to local welding shop if they didn't want to build the draw bar themselves. I under stand front wheels were in demand for building carts to pull malt-able drills and springtooths or harrows.
Raymond
Hi 98J
Ole' Marv had some real biggins to be dragging an IH 51 around the peaks with a D4 of any size, old or new. There was a bunch of IH 51"s sold in this area,(Paso Robles) along with the JD 36B. The biggest difference that most saw between the two, besides the manufacturer, was a IH 51 was handled nicely with an RD6 or larger while the JD 36B required a 3T D7 of a D6C at a minimum. Naturally some had less steep land and could do with less but on par the D6 was a minimum for the IH 51.
There were several Harris and Case pull machines in the area and I seem to remember that they wanted a 4R or 9U D6 for the Harris while there was a neighbor who used an RD6 on the Case machine to good success.
Really appreciate the photos that you are posting. Do you have any of a Harris 88 or 98 at work??
Thanks again for your effort.
Casey
support@acmoc.org
- Chris R
- Jason N
