- Thank you received: 737
"A" is 5-7/16 in.
"B" is 21/32 in.
"C" is 3/16 in.
I've used a pump-type oil can to fill any rollers that have been leaking, rather than the Cat tool. Even in the dealer shop, they never used the tool. They just stood the rollers on end after reconditioning and slowly poured in a measured amount of oil.
In general, if you have leaky rollers, you nearly always have excessive bushing to shaft clearance, rather than just worn seals .. and the rollers are on their last legs.
Quite often you can top them up, and they will fail totally the next day, as the bushing clearance and shell-to-shaft movement becomes too great, and the seals just let all the oil go within a short period.
As a general rule, any part that is worn 50% or more, is regarded as being past its reusability point, and needs to be replaced.
I meant follow the directions/instructions for using the tool ( or fabricated substitute) as the proper way of filling along with the description and reasoning for the process.
cat@acmoc.org
- Chris R
- Jason N
