Hello all!
Looking through posts, this one seems a pretty good one to spin off of, albeit the title says #12 grader vs a 212 9T I’m working on getting home. I kept it on this as Deas’s description of the tandem drive is helpful.
A couple of things-
1. Both rear chains are broken, one is dropped off sprockets but the other is bunched. No sign of broken case. Front chains are intact.
2. When I looked at it, the transmission shifter was stuck tight, but in neutral, I think. I’m not 100% sure on neutral because when I looked at it the owner had drug it from its outside parking spot about 30 feet with tandem wheels not turning and moldboard down.
3. It’s got over 7,000 hours on service meter, but used by same family since early 1970’s.
Current owner has both motors starting. After a little working with it, the shifter has movement to where it will drive forward in two gears, and in reverse. Movement is limited and I asked him not to push it as I think it’s due to the bunched chain. When I pick it up, I’m hoping I can get the bunched chain out of there entirely. Also, the left side gear box has a small rust hole, leaked fluid out.
Couple of questions:
1. Does lack of shifter movement put up any red flags other than for having sat outside for 20 years? Parts book shows shifter forks-maybe it’s like my F/A 560 that hangs up occasionally, (no Torque Amp on this to help out).
2. How does the wheel lock function? There is very little foot clutch pressure and wondering if that’s a cause of the stickiness.
3. I’ve found a couple used 7B1447 chains. Wondering if new are available and if used, what should I be looking for. What new length spec? I think those are 29 links, same chain all around for each drive wheel.
I have picked up a #12 OM and Parts Book; #12 8T1 Parts Book; 212 9T tandem drive parts book; 212 tandem drive 1R1 parts book. Haven’t found 212 grader service manual but have seen 311/212 diesel service manual but not ordered anything yet, too expensive.
I’m hoping to get that bunched chain freed up and use the front tandem rear wheels to get on trailer, or at least get it out so I can push the machine on and off.
I’ve got a couple of projects for this machine this spring and hoping to use for any snow we get this winter.
Thanks in advance, as always and keep safe,
bernie
