D47U Final Drive Removal
3 weeks 6 days ago #261274 by Alexjfrench
Can someone tell me how to remove what the book calls "bearing cage holder"?  The book says all I need to do is back the spanner nut off (counter clockwise) until it pushes the assembly off.  I backed it off as far as I could with a huge hook spanner and even used a punch and hammer to put as much tension on it as I could but it wouldnt pop off.  Anyone ever had this issue? (FYI the nut in the picture was backed off when I tried to remove the assembly)
3 weeks 6 days ago #261278 by gemdozer
Replied by gemdozer on topic D47U Final Drive Removal
This big part on the shaft is the holder and I removed maybe 20 off them by using a sledge hammer and loose the shaft nut 2 turne
3 weeks 6 days ago #261279 by Alexjfrench
You used a sledge on what?  The spanner wrench?
3 weeks 5 days ago #261289 by gemdozer
I was hitting the older
3 weeks 5 days ago #261293 by neil
Replied by neil on topic D47U Final Drive Removal
I'm amused that Alex's name is French and Hector is Quebecois : ) My understanding is that Hector's saying he taps the bearing holder with the sledge then turning the spanner nut to inch the holder off
3 weeks 5 days ago #261304 by trainzkid88
i would clean all the crap off of it before you go much further. i think what gem dozer means is while applying force to the adjuster nut with the wrench smack the holder with a hammer to shock it loose.
3 weeks 4 days ago #261313 by Alexjfrench
I have tried beating on the holder with the spanner nut as tight as possible trying to push it off. I guess I will try and put a gear puller on the holder as well. There are actually 2 ears on the holder that I could attach the puller to. Kind of hard to see them in the picture though. Hopefully between the nut and the puller that will apply enough force to get it to pop. This design kind of sucks. Cat should have put threaded holes in the holder to allow a puller to be used.
3 weeks 4 days ago #261315 by gemdozer
I just recheck your older picture and the sproket shaft nut has to be loosed more because the 2 pines for lock stop the holder to coming out
3 weeks 4 days ago #261316 by Alexjfrench
Yeah I tightened it temporarily when I was trying to get my gear puller to fit.  The nut was all the way backed off when I was trying to pull it.
1 week 6 days ago #261452 by JohnAU
Replied by JohnAU on topic D47U Final Drive Removal
Just wondering if you managed to get it off? I am in a similar poition with an old d46u I am dismantling for parts. I was thinking I would follow the instructions in the book and when its as tight as I can get it, I would use heat on the outer around the shaft. Hopefully that will come loose and I will be able to keep using the c spanner to remove it completely.
The following user(s) said Thank You: Haus
