This big part on the shaft is the holder and I removed maybe 20 off them by using a sledge hammer and loose the shaft nut 2 turne
You used a sledge on what? The spanner wrench?
I was hitting the older
I'm amused that Alex's name is French and Hector is Quebecois : ) My understanding is that Hector's saying he taps the bearing holder with the sledge then turning the spanner nut to inch the holder off
i would clean all the crap off of it before you go much further. i think what gem dozer means is while applying force to the adjuster nut with the wrench smack the holder with a hammer to shock it loose.
I have tried beating on the holder with the spanner nut as tight as possible trying to push it off. I guess I will try and put a gear puller on the holder as well. There are actually 2 ears on the holder that I could attach the puller to. Kind of hard to see them in the picture though. Hopefully between the nut and the puller that will apply enough force to get it to pop. This design kind of sucks. Cat should have put threaded holes in the holder to allow a puller to be used.
I just recheck your older picture and the sproket shaft nut has to be loosed more because the 2 pines for lock stop the holder to coming out
Yeah I tightened it temporarily when I was trying to get my gear puller to fit. The nut was all the way backed off when I was trying to pull it.
Just wondering if you managed to get it off? I am in a similar poition with an old d46u I am dismantling for parts. I was thinking I would follow the instructions in the book and when its as tight as I can get it, I would use heat on the outer around the shaft. Hopefully that will come loose and I will be able to keep using the c spanner to remove it completely.
