1942 D47J D4400 pony motor crank journal specs
2 weeks 2 days ago #261230 by trainzkid88
yes you can double stack rings and it will sort of work you can also get "cords" type rings which are a multi segment ring.
3 days 13 hours ago #261399 by CamaroMan
well got pony back together 2 days ago- Found aftermarket ring packs for 20 bucks each. I had zero valve lash on one side and ring gaps were HUGE.. in the 100 thou range!! almost as thick as the darn ring. Anyway for less than $300 i shd be back up and running with all internals in good shape.
I machined my own main bearing with the 50 thou I found during disassembly and it came out RIGHT on the money. Set ring gaps and valve clearances (prob a little wide) - i thought spec was 12 thou on pony seems it was 8 oh well she will run ok as is at 12.
3 days 13 hours ago #261400 by bernie
All very good news. Anxious to “hear” your success. If you can share part numbers / suppliers, it’ll likely prove helpful to many.
Best and keep safe-
3 days 13 hours ago #261401 by CamaroMan
Here is the bushing - came out nice and was a perfect fit in the block and final end play.
Bushing came out perfect - very happy! Got holes lined up perfectly too-
3 days 13 hours ago - 3 days 13 hours ago #261402 by CamaroMan
Part numbers are here:$11 - Bushings were 2-1/4 OD and 1-7/8 ID stock from an ebay seller. Didnt touch the OD and it was a perfect interference fit - medium taps with hammer to get it in- I had to remvoe a minimal amount on the ID to get around 2 -2.5 thou clearance.
$11 - 2-1/4" OD x 1-3/4" ID Plain Bearing Sleeve Bunting CB283616 Cast Bronze C93200
$7 / Pair Rod bearings 3B7938 - From AFTERMARKET.EXPRESS - GREAT ppl top deal with. Had seals and gaskets for SUPER cheap. Shipped fast and responsive.
$22: Piston Rings (ebay seller): Caterpillar piston rings D2 D4 69.85mm STD 6B2848 D315 955C. Came with extra Compression ring too!
$100 - Connecting rod, ONE on ebay I found - exact part
Crank Journal polished up real nice on the home made polisher from an old ryobi belt sander -
Last edit: 3 days 13 hours ago by CamaroMan.
The following user(s) said Thank You: bernie
3 days 4 hours ago #261406 by Busso20
CamaroMan, Nice machining work there, bushes look great
Time to create page: 0.165 seconds
