1942 D47J D4400 pony motor crank journal specs
Thank you received: 11
2 weeks 6 days ago - 2 weeks 6 days ago #261168
by CamaroMan
Hi - can someone post the specs for the pony motors crank journals? mine threw a rod cap and destroyed #2.
Thank you received: 96
2 weeks 5 days ago #261175
by CamaroMan
thanks - ordered a copy but its on its way need to go mic journal today and find unobtanium bearings. I have found other brands with the same journal ID bearings i might try modify- around $8 a set so well worth the attempt
Thank you received: 678
2 weeks 5 days ago #261179
Do let us know if you find a workable alternative as it'll be useful information to share - thanks in advance!
Thank you received: 279
2 weeks 5 days ago - 2 weeks 5 days ago #261182
by rax200
Caterpillar still has oversized bearings for the ponys
.020 us 3b7938
.030 us 1h2831
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Last edit: 2 weeks 5 days ago by
rax200. Reason: Added part numbers
Busso20
2 weeks 4 days ago - 2 weeks 4 days ago #261187
by CamaroMan
well i found bearings believe it or not, $7 a piece - and im going down the rabbit hole but 44mm piston rings come in 1.5mm thickness, the original pony engine rings come in at 3.1mm - so if i stack 2 rings ill be 0.1mm below spec and have gapless rings - no blow by! I did this on a tohatsu outboard and its been working perfectly-
my gap was near 2-3mm! I recall seeing blowby out of the top oil fill -
also found a con rod on ebay - lucky me exact part #, ONE left.
2 weeks 4 days ago #261198
by rax200
Cat still has rings for sale
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
Busso20
Thank you received: 810
2 weeks 3 days ago #261210
cat has the main bushing too. jp pistons(nerada automotive) in south aus has replacement pistons and rings. check the bores for wear, they have oversize pistons as well as standard.
2 weeks 3 days ago #261212
by CamaroMan
found some generic rings - im gonna double stack em for a gapless setup. Hones out cylinders yesterday that seem ok- im not too concerned for a perfect engine pretty sure itll run just fine. every $35 for a cat parts goes from $200 to $500 and im super tight on $. sitting with a boatyard full of boats to sell..
Busso20
2 weeks 2 days ago #261229
well you know boat stands for break out another thousand.
and they are holes in the water you pour money into.
there is a song about it by aussie bawdy comic kevin bloody wilson if it floats or flys rent it by the hour.
Time to create page: 0.192 seconds
