Winch cable question
1 month 1 week ago #261003
by Breadler
Working on a model 53 winch (D5C) and ready to replace the cable with 200’ of new 1/2”.
The existing cable was the typical nub/ferrule and pocket, however it was then threaded through a passage on the center of the drum, before winding. Is anyone else familiar with this? What I find odd, is that the passage is smaller than the ferrule, which means I can’t use a swaged ferrule and a swaged thimble eyelet at the working end. Wire clips will be a simple solution, just curious about that center passage.
Thank you received: 12
Thank you received: 824
1 month 1 week ago - 1 month 1 week ago #261006
You need the proper size swedged ferrule...1.63" diameter/42mm and 2" long/51mm.
1 month 1 week ago #261008
by Breadler
Yep, I believe it is the #B4, 1.63x2.00.
Still hoping to get insight on just running the ferrule in the pocket with the retaining cross pin, vs that plus feeding through the cross passage on the drum.
Thank you received: 36
1 month 1 week ago #261012
by jbernd56
feed the cable through the drum and let the end stick into the square pocket and pour lead around itl
1 month 1 week ago #261013
None of the literature I have shows anything about attaching the cable. How close is the fit that is preventing you from threading the B4 ferrule? Could be you can attache either way although I would tend to go for the original version.
1 month 1 week ago #261046
by Breadler
The passage through the drum is probably 1/2” smaller, than the O.D. Of the ferrule.
The work around would be to use wire clips at the working end. Just not as “clean” as a swedged loop.
Or…use a two piece ferrule, like what is used to repair a choker.
Thank you received: 810
1 month 1 week ago - 1 month 1 week ago #261051
as another suggested cast a lead slug around the cable end what actually holds it is the wraps of cable on the drum. the slug only stops it slipping till it grabs tight on the winch drum. the book will say the minimum number of wraps. never go below that.
many cables used to be terminated this way. often a ferrule was fitted over the cable and then that would be filled with lead.
a note with using cable clamps you want the pinch on the slack side of the loop not the line side so it is always straight and isnt deformed as that creates a stress point where it can fail.
Thank you received: 134
1 month 1 week ago #261057
by side-seat
Slang translation: "Never saddle a dead horse"
Time to create page: 0.237 seconds
